Page 382 of 775 FirstFirst ... 282332372378379380381382383384385386392432482 ... LastLast
Results 7,621 to 7,640 of 15487
    Oct 2009
    #7621
    Thanks Sir Ed. Kamusta ang hatak with the 225/55? I noticed you have a VVTi unit as well. Is that an MT or an AT?
    Ayos naman Sir IMm29. Felt na tumaas yung ride which is OK since nasanay na din tayo lately because of the upgrade we did dun sa new Ford Ranger (17 to 20 naman). Less tagtag surprisingly and more kapit and stability sa road. My unit is MT po. 2008 model. Lastly, mas naging mas pogi si Innova :-)
    Oct 2011
    #7622
    kailan ang launching ng new 2014 Innova (Facelft)?
    #7623
    Quote Originally Posted by ebmosqueda View Post
    Hehehe! Malayo naman sa tangkad ng White Ranger mo. But yes, from the stock 15s, your 225s will give the Innova more height. You're right about the ride, reduced bounce and better stability. Bumigat kasi. Hehe! Our unit is about a year ahead of yours. No complaints about the ride and the looks with the 17s, it's just the response that suffered a bit. Ours is an A/T, so i suppose that's what magnifies the feel of the lack in torque. Hehehe!
    Thanks for your feedback.
    Dec 2009
    #7624
    [QUOTE=IMm29;2241928]For 17" wheel users, what size of tires do you use?[/QUOTE
    Mine is 215 55 17 size ng tires k
    Feb 2011
    #7625
    Quote Originally Posted by timo07 View Post
    Fluid type.
    Fluid type shocks... is it ok to replace it with a gas type shocks? or the ride quality will suffer?
    Sep 2009
    #7626
    Sabi ng Sa naming yung roof rails daw ay walang load bearing capacity and purely for aesthetics lang.
    How true is this? Ang mahal pa naman ng roof rails sa casa, 18k.
    Oct 2011
    #7627
    sir, ano ba ipapatong mo sa roof rails?
    Sep 2009
    #7628
    A roof basket for out of town trips. It will be loaded with a cooler and several luggage.
    The casa said it cannot even bear a spare tire's weight because it is not bolted to the pillars for support.
    Sayang naman.
    Jul 2013
    #7629
    Just got my lto sticker last week, plan ko sana ipatint ung innova ko by dec. Anu ba maganda, wag muna idikit lto sticker sa windshield. Sori kung ot. Need ur advice lng.
    Jul 2006
    #7630
    Quote Originally Posted by ero124 View Post
    lagay ka na lang ng box na sukat para dun sa sticker mo boss para yearly yun lang ang inaalis mo
    Jul 2013
    #7631
    Quote Originally Posted by sirmykel View Post
    Parang mahirap yan sir ah! Baka matuklap ung tint pag tinanggal ko ung sticker. Pwede bang ilaminate na lng un tapos saka idikit. Wori lng ako sa mga enforcer bka di kita sa labas.
    Jun 2004
    #7632
    Wag mo na lang idikit muna, basta nakalagay yung sa plates at dala mo yung OR/CR copies ok na. pag tinanong ka ipakita mo na lang yun sticker tapos sabihin mo magpapatint ka.
    In my case three years na ako nde nagdidikit ng sticker sa windshield.
    Oct 2009
    #7633
    Ako din. 3 rides ko wala sticker sa wind shield ever since nakuha ko from the casa starting way back 2008. Kala ko nga di na uso yan e kase wala na din ako nakikita. Important lang e yung sticker sa plate mailagay.
    Oct 2011
    #7634
    itago mo na lang sa glove compartment yan sir. basta ung license lpate sticker naka dikit.
    Mar 2012
    #7635
    mga sir, na experience nyo ba ito, innova j gas yung car ko, nag palit ako ng battery kahapon ng tanghali. after the install, pina start lang yung engine para ma check kung ok yung charging. ok naman. 14v daw ang reading. mga 6 pm ko na ginamit yung sasakyan. at first ok naman. after 10 minutes, biglang bumaba yung rpm ng 500 rpm. para siyang mamamatay. buti na lang bumalik uli ng normal after another 15 mins.. pati yung A and B odo meter ko, nag reset. ganoon ba pag electronic? nag palit lang naman ako ng battery? tnx
    Oct 2011
    #7636
    hindi normal yan sir. baka alternator mo ang diperensya hindi kumarga kaya namamatayan ka.
    #7637
    sounds like a loose connection in a major electrical link. that's the only reason i can think of that can cause the tripmeters to reset..
    Jan 2012
    #7638
    Quote Originally Posted by gygie View Post
    Nagreset po yung ECU nyo sir. ganyan po talaga pag may on-board computer ang auto.
    Mar 2012
    #7639
    ngayon naman normal na siya. nakakapag taka lang kasi, battery lang naman yung pinalitan eh nagka problema na ng ganoon. kung ECU reset naman, ano kaya ang cause niyon? thanks guys.
    Jan 2012
    #7640
    This happens to me po everytime I disconnect the battery for more than 1 hour. Yung ECU po, re-learns the current car settings in a while kaya po normal na ulit. sabi po nila sa casa, para mas mabilis, going back to normal, just turn the acc to on but don't start the engine, depress the accelerator way down slowly then turn it off for 1 minute before starting the engine. drive for 15 mins, at min of 2k rpm with a/c / radio/ etc turned off.
    One reason po for this, I noticed was the clogged throttle valve.auto adjust po kasi yun, tried cleaning this off with carb cleaner, pati na din po yung MAF sensor with elec-contact cleaner.I changed the spark plugs na rin. ayun po, di na kailangan gawin ung advise ng casa.
    thanks
Toyota Innova Owners & Discussions [continued 3]
