Page 379 of 775 FirstFirst ... 279329369375376377378379380381382383389429479 ... LastLast
Results 7,561 to 7,580 of 15487
    Aug 2006
    #7561
    Quote Originally Posted by timo07 View Post
    Hi, mayroon ba sa inyo nakakaalam kung adjustable ang front suspension para sa clearance ng tire with the fenders? Parang masyadong dapa kasi yung sa kin then awkward sya against the high clearance sa rear. May nakikita ako ibang innova maganda ang clearance sa harap. Tinanong ko kasi sa kasa pero hindi raw puede. Nung tinanong ko naman kung bakit ibang innova malaki ang clearance, di naman masagot.
    If you remember in this thread, there's a discussion on uneven front height for driver side and passenger side and the dealer's solution was to replacement rubber spacer in between the body and the ladder chassis.
    Dec 2007
    #7562
    Quote Originally Posted by Mile2 View Post
    Thanks Mile2. Yes, I remember the discussion. Do you know if a proper and taller rubber spacer can be sourced from Toyota or elsewhere? I reckon I need a 1 to 2 inch taller spacer to get the desired lift.
    Oct 2011
    #7563
    Yup OEM the left one lasted 5years right one 6years and 11 months. Dahil deads na yun dalawa balak ko na palitan bulb.
    Sent from my iPhone using Tapatalk - now Free
    ah okay sir. mukhang malapit na rin taning ng buhay ng foglamps ko. napalitan mo na?
    Jun 2006
    #7564
    Changed my foglights to hid . Superyellow. Di nman nakakasilaw kasi mababa ang location.
    #7565
    Not yet, maybe this week. Madali lang ba palitan ng bulb? I assume hindi naman kalas bumper?
    May 2011
    #7566
    Good Day!
    Ask ko lang po kung cover ng warranty yung shock absorber? Kasi mo may leak yung front shock ko sa passenger side.
    My ride is toyota innova 2011 d4d m/t E variant. April 2014 pa po siya mag 3 years.
    Thanks po.
    Jun 2006
    #7567
    Covered ng warranty yan, nasa 4k each ata bnew nyan sa casa. Rear shocks are at 1k each. Insist that they replace both sides para pantay ang tigas. Ewan ko lang kung papayag sila.
    May 2011
    #7568
    Quote Originally Posted by shibby75 View Post
    Thanks.
    May procedure ba kung pano mag claim ng warranty? Dapat nga palitan nila pareho kc di pantay pag isa lang papalitan.
    Sana pumawag ba both shocks will replaced.
    Thanks Again.
    Aug 2006
    #7569
    Quote Originally Posted by 1845ers View Post
    Thanks.
    Thanks Again.
    Actually papalitan lang nila yung sira, di sila magpapalit kung buo pa.
    Aug 2013
    #7570
    I just got around to installing an "AORTO" brand spare tire lock. Cranking the spare wheel chain is a b*tch. The crank keeps on slipping on the slot every 90º or so unless I apply pressure at the end of the crank (my palm still hurts!). Is there an aftermarket crank handle with the traditional "T" end like this one: http://webpages.charter.net/smizwhiz/tools.jpg
    I can Imagine doing this in mid-day heat with a flat tire .
    Oct 2011
    #7571
    alam ko mabilis lang yan sir pwede DIY. nasa instruction manual din pagpalit ng foglamp afaik.
    Aug 2006
    #7572
    Quote Originally Posted by Pao11 View Post
    Reminds of my friend who owns a Nissan Urvan, he was trying to take out the spare tire underneath and continuous to have that slipping cranks. All the while he thought he was doing the right thing but he did not notice that the chuck end he was using was the square one - so it always slips out., it is suppose to be the hook end that is to be used as chuck key.
    Innova also uses the hook end (?) to lower the spare tire.
    cheers!
    #7573
    madali lang po palitan ang bulb sa fog lamp... mas mahirap pa konti ang sa headlight.
    #7574
    cheers!
    Mine is hook end. And yes hassle kasi kumakalas siya. Nabadtrip ako pina welding ko na, now permanente na yun 3pc na metal.
    Aug 2013
    #7575
    cheers!
    Yes. I was using the hook end. It is a bit thick. I might try to pound it a little to make it slimmer .
    Feb 2011
    #7576
    ako I havent tried lowering the spare tire pa. I only checked how to unlock the spare tire lock (kinabit na kase yung lock upon release sa Toyota). Maybe I need to test it out.
    Oct 2007
    #7577
    Apologies if this has been asked before, too many pages to back read and my search has not produced results. Im planning to buy an Innova E sometime soon and want to have the door handles painted the same as the body color... dont want it black or chrome Where do you guys suggest I have this done? Sino mga suki nyo na magaling with this?
    Thanks in advance
    #7578
    Quote Originally Posted by altis View Post
    I suggest try it, better na gamay mo na para by the time na kailangan mo na gawin eh sanay ka na.
    #7579
    Quote Originally Posted by 31gna View Post
    Thanks in advance
    Chrome yung door handles ng E diba?
    Can you repaint a chrome finish?
    Or plan mo palitan totally?
    Oct 2009
    #7580
    Thanks in advance
    Try mo plasti dip....search mo sa internet...yun lately ginagamit sa kotse daw e.
Toyota Innova Owners & Discussions [continued 3]
