Thanks for your replies and info sir CVT Mile2 and Retz! Appreciate it so much!
Hindi yata kaya ng ng walang baklasan ang cleaning., paano yung mga dumi sa cooling coils and fins ng blower fan?
Kaya nabubutas yung cooling coil dahil sa humid dirt that slowly penetrates sa surface ng aluminum tubes as explained by aircon technician to me., so it is important that it should be cleaned.
Ericson, ang reason why distilled water is preferred than purified is because of presence of minerals (meron pa rin kahit kaunti). Distilled or Demineralized Water ay wala na (as if hindi pa obvious sa term he. he.) Yung minerals kasi ang nagigiging scale. So mas maganda talaga ang Distilled, although using purified water should not cause you any trouble if you use coolant additives in the correct proportion. Coolant additives, at some level, provide descaling properties.
mga bossing..
tanung ko lang
. kapag i i-start niyu yung innova niyu hinihintay niyu pa ba mawala yung srs at t-belt logo..?
kyalangan pa ba hintayin yun mawala? ..
eh sir anu ba unang maapektuhan sa sasakyan. kapag palagi iniistart ng hindi na hinihintay mawala yung heater.?
lalo na sa umaga diresiretso agad i istart. .
Tsk![]()
Para tumagal yung life ng unit mo sir hintayin mo muna mawala yung ilaw ng heater seambol. Yan din yung nakalagay as manual.![]()
four possibilities:
1. the wheel is already perfectly balanced as is. lucky you!
2. it had a lead weight, but for some reason, natanggal o nabagsak. usually, there are visible marks...
3. the previous owner didn't bother to have it balanced.
4. the wheel is balanced. the weights are taped inside on the other (hidden) side of the mag. give it a peek.
if i were in your shoes and still have my doubts, i would have the wheel balanced. it's not that expensive.
No, first time ng Innova ko to have an aircon service after 5 1/2 years. My rear coil got busted due to dirt. Mas madaling dumumi yung rear dahil walang cabin filter, at lalong mas malakas dumumi ang rear coil pag di pinapaandar when driving dahil yung opening flaps na nasa likod ng rear bumper naka-open.
salamat bossing
ito nalang palagi ang issue ko . nahihirapan na ko kasi istart sila ng istart agad. parang ginagawang GAS
ingat na ingat ka sa auto. kapag sasabihan mo naman magagalit sayu .eh intensyon mo lang naman mag ingat.
palagay ko sa katagalan starter ang magiging sira ni innova
alam ko na papagawa ko :hysterical: hindi naman siguru ma aapektuhan ang engine sa ganyang habit
madalas ko sir issue to. eh kung ako lang hinihintay ko talaga mawala lahat ng indicator sa dashboard tsaka istart
wala naman kasi mawawala. kaya lang yung mga ibang gumagamit .
