guys ,im planning to install power window to my innova j.has anyone of you experience problems regarding the mechanisms of it? wanna hear so comments, thanks a lot!
pinagiisipan ko din lagyan ng power windows yung sa akin. medyo alangan lang din ako kasi di mukhang OEM karamihan ng available conversion kits. nakita ko dati dito yung nagpakabit ng Shark brand. mukhang ok naman kaso i'ved never had the chance to see the real thing yet kaya di pa rin ako sold into converting my manual windows![]()
Quick question sa mga guro. La kasi sa owners manual. How many Liters for 2010 Innova ATF fluid change? I know it requires Type IV ATF Fluid. Innova has A45DE Automatic Transmission yata. Fortuner has A340E Automatic Transmission na preho ng Tacoma 4 cylinder sa US. Required ng A340E is 2 Liter of ATF Fluid. I've been searchiing online. Sa CASA charges 4Liter of ATF fluid kasi 3.6L liter daw yata kailangan. Is it 2 liter of atf or 3.6 Liter of atf for our innova?
Thanks sa response. Anong page kaya sa owners manual nakalagay ang ATF capacity? Nakalagay lang kasi sa 2010 Toyota Innova owners manual na Fill up to 8 or 9 yata yong capacity, not the exact 3.6 lliters needed for ATF change. I guess we'll just measure ilan liters yong lumabas na ATF, then refill with the same amount. Tapos drive 15minutes to let fluid warm up, park the car go to L, 2, D, R tapos P then check the level just to be sure na di sya low. Do they put the A/T in neutral when they drain fluid? Parang dami yata pag 3.6Liters ang kailangan. Fortuner ATF requires 2 liters same as Toyota Tacoma 2TRFE (cylinder) na Automatic Transmission. Tacoma 2TRFE(4cylinder) A/T requires 2.1 quarts(2 liters) of Type IV ATF pero casa dito sa atin puts in 4 Liters na ATF sa fortuner. Nabasa ko rin sa tsikot na 2.5 liters ATF ng Innova which is close to 2 liters ATF of fortuner. Is it 2.5 liter of ATF or 3.6 liters for our innova? Thanks in advance!
Mga ka innova, question lang. Nangyari na ba sa inyo yung lumuwag yung negative pole ng battery tapos nung hinigpitan ko nawala na sa timing nung ginamit. Ano corrective measure dito? Thanks in advance sa magreply.
Sir, I'm very Sorry for the misinformed it is been 2 years ago na kasi since i changed my atf.... mali po ako, it's not 3.6 liters...In our manual nasa page 311. I uploaded a pics for you.
vvti po ang sa akin 2.4 liters.... i think mas maganda ang ano ang na drain mong ATF yun din ang idadagdag mong ATF.
Bro tinanggal ko ulit battery then switched on the ignition for 2 minutes to complete the cycle ng program tsaka ko ini-start. Will update you.
Thanks! We're doing 40K pms by ourselves. Change Oil, Change Diff, Chang ATF. Out of Warranty na kasi ang Innova. Fluid Capacities VVTI 3L Rear Diff, 2.4L ATF, 5.6L ENGINE OIL.
Parts:
35178-30010 GASKET, TRANSMISSIOn,
12157-10010GASKET, DRAIN PLUG REAR DIFF,
90430-12031 OIL DRAIN GASKET,
90915-YZZD2 OIL FILTER,
Texamatic 1888 for Power steerring
AIR FILTER
CABIN FILTER
Tools:
24MM socket for Rear Diff Plug
14MM socket for ATF and Oil Drain Plug
VVTI rin sa amin 1TRFE engine. What year na owners manual? Naka neutral ka ba when you drained your ATF? Mali yata parts counter ng toyota kasi 4L daw yong bilhin. I will just follow owners manual na 2.4 Liters of ATF sa innova kasi 1TRFE engine ng innova. 2 liters ATF naman ang Fortuner kasi 2TRFE ang engine.Di kasi nakalagay exact amount sa owners manual ng 2010 Innova yong ATF na kailangan. I'll just measure total drain amount tapos refill rin ng same amount up to 3 Liters siguro.
Encountered a problem with Innova just today. 1st, umingay sa loob ng engine bay (sounds like a loose fan belt) after 40mins, then the battery indicator light up, humina car horn, power windows and radio, I quickly switch-off the aircon. Alternator problem lang ba ito? If yes, how much ang damage? para more or less I have an idea pag pinagawa ko. TIA.![]()
