Page 255 of 775 FirstFirst ... 155205245251252253254255256257258259265305355 ... LastLast
Results 5,081 to 5,100 of 15487
    Jul 2003
    #5081
    Quote Originally Posted by first_light View Post
    To all Innova Owners,
    I just want to share to you my experience.
    Few months ago, my a/c started to malfunctioned erratically.
    The cool was inconsistent most especially when the weather outside is hot.
    I noticed that the pulley assembly doesn't activated/engaged when the a/c is switched on.
    But when I hit it with a stick so it will engage, it works ok.
    Few days ago, I went to one a/c shop for them to check it.
    They said that the pulley assembly's electromagnetic coil has degraded and needs to be replaced.
    They also said that it normally malfunctioned when it gets hot.
    I don't know if this is true but nevertheless, I asked them to change it since we badly needed the a/c to work properly.
    Now, my a/c is working as it was before.
    Can someone verify the malfunctioning of the pulley assembly when it gets hot?
    Or I should just asked them to clean it since I saw a lot of accumulated dust between the coil of the pulley assembly and that might caused the malfunction of the coil?
    Your inputs are highly appreciated
    looks like the magnetic clutch is beginning to fail.
    I have not heard of it failing under hot conditions but it will degrade over time (the same with most engine components) with heat as contributing factor.
    IMO, the dust is a non factor since the working component is encased inside that metal pulley.
    #5082
    Quote Originally Posted by ericson21 View Post
    i also have the G variant, yun nga lang eh 2011 model. there is a ABS icon sa left side, color yellow sya, nag iilaw pag naka ON ang ignition. SRS icon, walang ganun, airbag logo is parang upuan at may airbag, color red naman yun.
    yung sa airbag, yes 6 seconds mamamatay din yun. pero sa 2007 innnova ba may ABS ang G? tingnan mo sa liwanag, left side sir kung meron bang logo ng ABS dun na di lang umiilaw, kung wala naman, wala syang ABS.
    ellow mga sirs especially ericson21, meron syang icon ng ABS at icon ng SRS bag, sinilip ko na pareho at sa manibela may nakalagay na SRS airbag. pero yung nga pag naka 'On' na yung ignition switch within 6 seconds or more hindi talaga nailaw yng icons ng ABS at yung SRS icon ( na yng logo na may airbag at upuan) posible ba talagang malfunction na yung ABS at SRS nito? one more thing yng security button hindi na rin nag blink pag naka alis na yng key sa ignition switch. hula ko dahil ito sa pagpalit ng remote key dahil hindi na mismo susi ng toyota (remote) ang gamit kundi third party remote key.
    please advise po.. thanks.
    Jan 2013
    #5083
    Hi, mga bossing ask ko lang po kung ano KMS kapag papalitan mo na yung timing belt mo? kelangan pa bang antayin yung LED indicator na kelangan mo na magpalit, nasa 60+++KMS na kasi yung sakin. at saan ok magpapalit ng timing belt at how much kaya ang damage nito? aside sa casa kasi medyo my pagkamahal ang labor daw nila dun.
    Thanks in advance.
    - - - Updated - - -
    Thanks in advance.
    Oct 2011
    #5084
    Quote Originally Posted by brewsterjones View Post
    Thanks in advance.
    - - - Updated - - -
    Thanks in advance.
    sa manual nakalagay 150K but you could opt to have it change earlier. pwede *100K kasi ++ pa ung mga idle time mo. my colleague replaced his timing belt 12k ang damage.
    - - - Updated - - -
    Thanks in advance.
    - - - Updated - - -
    Thanks in advance.
    Jun 2005
    #5085
    How much is ba oil sa casa diesel innova? it's my first timeto purchase oil and let the gas station handle the change oil
    Jun 2005
    #5086
    Sablay ka, bro :
    2004 XM, XN, XP, XR, XS
    2005 XT, ZA, ZB, ZC
    2006 ZC, ZD, ZE, ZF, ZG
    XC is 2002.... Baka carnap o "iwas coding"
    17.5K:bruce_lee:
    Yup XC is 2002. Carnap recovered car or personalized plate or dating goverment tapos nilipat sa private
    Jun 2005
    #5087
    Share ko lang ..after 55,000 kms on my 2009 Toyota Innova Diesel AT. I finally changed my Yokahama Aspec Tires.Sobrang sulit pala ng mga gulong na ito.I rotated twice during the 55,000 period.No Oblong ,suffered no flat tire. AWESOME YOKOHAMA ASPEC TIRES>Syempre I changed to the original tires pa din.(I changed the 2 front tires only) Yung sa likod baka next month na lang. 4,150 isang tire..8,300 dalawang Aspec.
    - - - Updated - - -
    Sep 2004
    #5088
    hi guys pasensya na hindi ko talaga mahanap sa "search" ang topic na 'to.
    would you kindly post or point me to, step-by-step procedure on how to remove the aircon air filter (aka cabin air filter) of 2012 toyota innova? I would like to clean it manually. thanks.
    May 2005
    #5089
    Quote Originally Posted by CtrlAltDel View Post
    1. Remove glove box. This is the hardest part. Press on the glove box's side wall (preferably the side near the door) until you see the tab or stopper.
    Pic below is for illustration only and not from an Innova.
    2. Remove the cover of the air box.
    3.
    May 2005
    #5090
    Dec 2007
    #5091
    first_light, I'm assuming you are talking about the Magnetic Clutch and not the tensioner pulley. Was the shop able to change the clutch alone without changing the compressor? I remember reading here in tsikot that the Aircon Compressor and Magnetic Clutch is one whole assembly. Can you confirm the details of your fix? Thanks much.
    Reading through your post, it appears you might have witnessed the clutch being serviced. If you have pictures, can you share it with us? Going to your question, dust accumulation should not hamper the electrical operation of the coil. The coil induces a magnetic field that actuates the compressor engagement. Dust will not typically disturb this electrical function. What may happen is accumulated dust may hamper the mechanical movement but this may only be possible for severe deposits.
    Oct 2011
    #5092
    Quote Originally Posted by downshift2 View Post
    mineral oil toyota oem cost Php202/Li
    Nov 2012
    #5093
    Mga Sirs,
    Ask ko lang kung magkano aabutin ng 90,000 PMS. Mine is diesel, MT, G variant.
    Salamat,
    - - - Updated - - -
    Mga Sirs,
    Salamat,
    Jul 2011
    #5094
    1st time ko makakita ng innova , na sa manila naka rehistro peru hindi naka rizal plate
    ito siguro yung mga kauna unahan batch .
    NE Pacific- Robinsons Cabanatuan City?
    Feb 2011
    #5095
    Quote Originally Posted by biboypalaboy View Post
    pero kita mo ba dun sa panel sir na parang may kulang? bungi yung mga may ilaw kase may katabi yun na naka ilaw, yung airbag lang wala ilaw dun? yung ABS logo nakita mo ba sa left side sa sinag ng araw na may logo dun pero di lang talaga umiilaw?
    what do you mean sa security, kahit i lock mo yung sasakyan using the remote hindi na umiilaw yung security? kase dapat iilaw yun steadily for 30 seconds tapos after nun mag blink na sya indicating na the TVSS is armed. hindi ba ganun sayo?
    kung iba na remote nya, nilagyan na ng aftermarket alarm? nag aalarm naman ba when you press the panic button sa remote for the car to alarm?
    - - - Updated - - -
    Jul 2011
    #5096
    Magandang araw mga tsikot at innova lovers...
    ask ko lang nabasa ko kasi sa manual (salamat kay Number001 sa pdf file) na pag naka 'On' na yung sa ignition switch dapat po eh naka 'ilaw' na rin yung 'ABS' at 'SRS' icons within 6 seconds (aside from other icons na makikita sa service reminder indicators). Meaning pag naka ilaw yung ABS at SRS they are functioning properly.
    Problema ko po kasi eh, pag naka 'On' yung ignition switch eh wala pong ilaw yung SRS and ABS icons nya, ibig po bang sabihin eh may problema na yung SRS and ABS ng innova ko? (btw, 2nd hand lang yung innova na nabili ko, 2007 model G series), just in case may problema po, saan po unang titignan kung talagang may defect po talaga ang SRS and ABS?
    Salamat po and God Bless.
    baka may accident history ang acquired unit mo na deploy na yung airbag then di pinalitan ang airbag (mahal kasi) saka inalis yung lamp indicatornito para di mag-manifest na may problema. Ganyan kwento nung isang car na binebenta sa friend ko ng pinacheck sa dealership yung car lumabas sa result "deployed airbag".
    May 2012
    #5097
    Hi. Ask ko lang, kaya ba mag 140 ng d4d na innova? Yung '10 d4d g manual kasi na innova namin ay sumisigaw na ang makina pag dating ng 120 at feel mo din na may vibration. Napansin din ito ng dad ko habang dinadrive nya sa expressway. Gusto ko din malaman kung mas malakas ang matic na d4d innova sa torque kumpara sa manual kasi sbe daw 260NM sa matic tpos nsa 200NM daw ang manual. Thanks.
    Sep 2011
    #5098
    ^ kaya sir , mas mataas nga lang yung RPM ng manual kumpara sa AT . kaya ramdam mo yung galit ng makina kapag matulin , eh sa AT kasi mababa rpm nila kahit matulin na ang takbo
    Quote Originally Posted by MrQ5 View Post
    oo bro , tiga neuva ecija ka rin ba ?
    medyu OT sensha na MODS
    Jan 2013
    #5099
    Hi guys! im newbie here.. i just to ask and clarify something regarding the price/ inerest of the toyota innova that i got.. I got my 2013 innova G 2.5 diesel a/t last december 28, 2012.. i'm outside the country so my sister is the one made the transaction regarding the car.. at first the dealer told us that our dp will be 150,000 and the monthly amortization will be aroung 19000.. so i agree with that.. then he asked my sister that someone from the bank will call my other ( since the car will be name to my mother), and it was PSbank who called and approved us for the five-year loan and told us just to contact the dealer. so my sister called again the dealer and asked if how much will be our DP and monthly, he said the the same price 150K for the DP and arounf 19K for the monthly.. so the next day we decided to purchase the car since they have PROMO and it will only last till the end of december and went to TOYOTA DASMA to give the DP, we gave the 150K downpayment and toyota calculated again our month amortization.. in our surprise it was different!!! here it is:
    price of the car: 1,165,000
    20% DP: 150,000 ( supposed to be 233,000 but we were discounted by 83K)
    monthly amortization for 60 months: 22, 904..
    ALL-in (insurance, LTO reg and mortgage was included, also we have freebies like rust proofing, mat, tint, fuel, seat cover, cover for the car, labour services, etc)
    the amount of the inerest for the 60 months that i computed was around 360K
    I WOULD LIKE TO ASK IF IT IS TO MUCH OR MOST LIKELY THE INTEREST FOR THE 60 MONTHS PAYNET WILL COST LIKE THAT? HOPE YOU GUYS CAN ANSWER
    - - - Updated - - -
    #5100
    Quote Originally Posted by nova2013 View Post
    - - - Updated - - -
    that sounds about right. pero, to get the best deal talaga, dapat kumuha kayo quote from several banks and haggle..
Toyota Innova Owners & Discussions [continued 3]
