Page 186 of 775 FirstFirst ... 86136176182183184185186187188189190196236286 ... LastLast
Results 3,701 to 3,720 of 15487
    May 2007
    #3701
    Quote Originally Posted by pingpongdad View Post
    any suggestions for cleaning the blackened areas on the beige ceiling of our innovas? especially seen near the vents of the aircon? car shampoo, upholstery fabric cleaner? thanks a lot
    Try Joy dishwashing liquid diluted with water... This is what I use in cleaning my Innova's headliner.
    Jan 2011
    #3702
    Quote Originally Posted by MrQ5 View Post
    kaya mas mabilis umitim sa diesel oil mas mataas kasi ang detergency content compare to gasoline rated engine oil, as well as anti-wear and tear contents for diesel. At pede din ang diesel engine oil for gasoline engine, madalas mas maganda ang diesel oil kaysa sa gasoline engine oil.
    I agree, maraming detergent kasi nga high sulfur ang diesel dito sa atin. That's why recommeded na oil is only API CF or CF-4 for toyota innova d4d diesel. Owners manual suggest an API CF or CF-4 for diesel Innovas here in the Philippines. Suflur ng Diesel dito sa Pilipinas is at least 500PPM, other countries 50ppm na lang. Kaya nga hindi EURO IV compliant ang diesel dito sa atin. Dirty Diesel causes the Suction Control Valve or SCV D4D dreaded problem. Toyota rectified the problem by improving and making the SCV bigger and longer and wont clog yong SCV. Mura lang naman paayos nito, less than P10,000 yata. Kaya nga lang you will never know when your engine will stall. High maintenance sa diesel, High Gasoline Prices sa Gas. Dami namang mekaniko ng diesel dito sa atin. Kaya just take your chancesna lang. As per Owners manual, Innova diesel oil recommended oil dito sa atin is API CF-4, CF, CD, CE and not those high API ratings for diesels API CJ-4, CI-4 PLUS/CI-4/CH-4/CG-4/ SM/SL/SJ ACEA E7.
    May mga diesel oil na hindi API SL, SM rated Not all diesel oil are recommeded for Gasoline engine and not all Gasoline oil are rated for Diesel engine. Meron mga Gasoline oil na SL, SM rated and also CF rated. So pwede sa Gasoline and Diesel.
    Recommneded oil for Innova from Owners manual.
    Gasoline engine: API SL, SM grade 5w-30 or 10w-30, 15w-40, 20w-50
    Diesel engine: G-DLD-1, API CF-4, CF, CD, CE
    Example of an Oil that is recommended for both diesel and gas engine
    Mobil1 has SM/SL rating for gas, CF rating for diesel
    From Mobil1 website
    Mobil 1 10W-30 meets or exceeds the requirements of:
    ACEA A1/B1, A5/B5
    API SN, SM, SL, SJ
    ILSAC GF-5
    Mobil 1 10W-30 is of the following quality level:
    General Motors GM-4718M
    General Motors 6094M
    API CF
    Check your owners manual for recommended oil viscosity and rating!!!!
    #3703
    Quote Originally Posted by ericson21 View Post
    no kalog dapat yun, saken never nagkaron ng kumakalog sa lubak at wiggle kahit 140 (gang dun ko lang kasi sa 140 pinapaandar innova ko hehe.) no wiggle at no kalog dapat yan, D-4D yung saken.
    Hard to believe yata ito pre. Kahit nga pitikin mo lang ang kambyo gumagalaw na. So malamang kung dumadaan ka sa humps ay gumagalaw yong kambyo mo. Never nagkaroon is too much claim. Diesel ka pa eh ang ingay nga nyan.
    May 2005
    #3704
    Does the 2012 Innova G come with speed sensing auto lock?
    #3705
    Yes, both G and V variants. It locks automatically once you drive a few meters above 20 kph.
    #3706
    Quote Originally Posted by vic2rem View Post
    From Mobil1 website
    ACEA A1/B1, A5/B5
    API SN, SM, SL, SJ
    ILSAC GF-5
    API CF
    A very informative post, vic2rem. Thank you.
    I never owned a diesel vehicle but even local sub compact cars are starting to appear with diesel variants.
    I am open to having one with common-rail injection system but is afraid of the black smoke ,noise and maintenance cost.
    I too have witnessed new Fortuners and Innova D4D with 2012-2014 LTO stickers already belching black smoke when accelerating.
    Regarding maintenance, what's the difference in maintenance procedures and cost of a Gas and Diesel engines?
    The little knowledge I have is there are no sparkplugs for diesel engines and after some thousands of Km you need to have it overhauled.
    Feb 2007
    #3707
    How mabebenta ang 2012 acquired Innova D4D E stock mags & tires with 3,000 kms. odo.?
    Oct 2011
    #3708
    From Mobil1 website
    ACEA A1/B1, A5/B5
    API SN, SM, SL, SJ
    ILSAC GF-5
    API CF
    naging oil discussion na ah! I was surprised that you mentioned higher API rating like CH-4 & CI-4 is not recommended for Innova Diesel. I know that only API CJ-4 which is especially formulated for Euro 4 compliant fuel is not recommended. Anyway, just wanted to clarify lang regarding this matter. I think oil gurus could shed light on this. Thanks.
  9. #3709
    ok ba 16 or 17"s na rims sa Innova without sacrificing too much ride quality? what tires kakasya?
    Jul 2011
    #3710
    ano ba pinag-uusapan nyo? steering wheel? o yung lever ng kambyo?
    kung may konting vibration sa steering wheel pag high-speed (140kph), siguro for balancing na ang wheels.
    yung sa shift lever naman di talaga visible ang vibration nito unless you will hold and change gear/push it to the sides while in neutral.
    #3711
    Oo nga baka nagkalituhan na. Ako kasi yong nagtanong.
    Ang tanong ko eh yong kalog sa...
    kambyo a.k.a shifter a.k.a. joystick a.k.a transmission lever
    Kasi sa mga kotse namin dati from Mitsu to Honda to Hyundai ay di ito gumagalaw o nag-vibrate. Ito rin ang specs nila repapips sa Mitsubishi transmission plant sa Canlubang.
    Pero pagdating ko sa Innova, nagulat ako na palaging gumagalaw ang kambyo. Parang jeepney.
    Anyway, mile2 gave a very good explanation.
    Ito yong iriginal tanong ko:
    Quote Originally Posted by happymeal View Post
    Normal lang ba na kumakalog left to right ang M/T shifter kung dumadaan sa rough roads? Tapos sa smooth roads ay may slight wiggle sya? Sa Transmission factory kasi ng Mitsubishi dati nag work ang tatay ko at sabi nya ang isang no-no sa kanila ay ang vibrating transmission shifter. Dapat daw ay di ito kumakalog. Sa mga kotse ok naman pero sa innova ang lakas lalo na sa lubak.
    Oct 2011
    #3712
    alog sa kambyo sa innova vvti? highly unlikely.
    #3713
    Meron pre. Try mo pitikin sa iyo. Gagalaw. Kaya pag daan mo sa humps, gumegewang left to right yong kambyo.
    Jun 2007
    #3714
    Once you hit 30kph it automatically locks myself
    Jul 2011
    #3715
    well may vibration ang shift lever pero wala pa kasi ako nagamit na M/T na sasakayan na walang vibration sa shift lever unless kung di na M/T at fly-by-wire na ang gamit. almost same vibration chac ng everest 2.5L at ng adventure ime.
    vibrating lever. Yes.
    Shaky lever. No.
    Jul 2011
    #3716
    Quote Originally Posted by aki0125 View Post
    be sure you always have the key to unlock yourself once he drive 30kph.
    Jan 2011
    #3717
    As per Owners manual, Innova recommended Diesel oil CF-4, CF, CD and CE. You're right about the CH-4 and CI-4. Both CH-4 and CI-5 exceeds the performance of API CD or CE. CJ-4 is not recommended because of our high 500ppm sulfur. For Diesel innova, Toyota recommends API CF-4 and CF but may also use CD, CE rating and CI-4 and CH-4 can be used in place of CD & CE Diesel API ratings! Most oil still carry the old CF-4, CF rating which is the recommended diesel oil for Innova.
    Obsolete: API CG-4, CF-4, CF-2, CF, CE, CD-II, CD, CC
    Current: API CJ-4, exceeds perfomance of CI-4 CI-4, CG-4, CH-4 but not for higher than 15ppm suflur,
    Current: API CI-4 can be used in place of CD, CE, CF-4, CG-4, CH-4, CI-4 plus
    Current: API CH-4 can be used in place of CD, CE, CF-4, CG-4
    #3718
    run that by me again??...
    Jan 2011
    #3719
    For Innova, Diesel if you have a driver, Gasoline if you're the one driving. At least di mo na problema pag tumirik, I've experienced sumakay sa tumirik na Isuzu Dmax, Hilux. My cousin mentioned problem with his strada. Lahat clog diesel fuel system(Filter) For smaller car, Gas is ok kasi liit lang naman difference in terms of fuel consumption. Innova gas has timing chain, Diesel has the timing belt. Diesel has P500 cheap fuel filter but needs changing frequently to prevent SCV problems kasi nga of our dirty diesel . Gas has P3,000+ fuel filter but would last at least 80K as per owners manual. PMS you can go every 10K for gas innova with no warranty issues basta synthetic. Diesel needs frequent oil changes pero pwede naman ordinary oil pag every 5K. Pag 100K plus na, sigurado kailangan mo ng calibration, etc. Pero mataas resale value ng diesel keysa gas. Pag consume more than 15K every year, diesel siguro. Less than that, you can go for a gas innova. Pag diesel, just get rid, sell it when it's time to change the timing belt at 100K para less worry sa maintenance.
    Jun 2007
    #3720
    I have here a lot of mobil1 5W-30 SM SN CF rating. I use this oil for my pick up truck. So its safe to use this for the innova as well? Looks like i need to sweet talk my service advisor to allow me to bring in my own oil with the corkage fee
Toyota Innova Owners & Discussions [continued 3]
