That's correct, I spent less than P10K with a cooling coil replacement plus cleaning after 5 years, really worth saving rather than yearly cleaning that will cost around P12-15K in 5 year span.
But now I know that is also important to clean the rear cooling assembly yearly. Somebody post here how to clean the rear aircon in detailed steps, I just can't locate it by back reading the threads, anyway it's not that hard to disassembled the rear aircon just take out the seat and sidings and you can now access the aircon assembly.
good morning mga boss! i'm a newbie here on this thread.. hi to everyone! btw i'm selling my brand new equinox car dvd player. 2DIN hdtv9100ibGPS. 800x480 resolution nya,may bluetooth,tv tuner,built in GPS,auto back up camera mode(kahit naka off pag nag reverse shift kana aandar sya!),ipod charging and play,dust proof mechanism,electronic and mechanical anti shock.mos-fet, 50w x 4 output nya.motorized yung 7" TFT color LCD nya. 160x182x52 mm DxWxH
mp4(avi,divx,3.x,5.x),dvd,vcd,svcd,wma,cd,mp3,jpg.
for 20k only (neg)
rfs: ayaw ng nanay ko palitan yung stock HU ng innova namen.eh ako ayaw ko din ng conflict kaya benta nalang.
Eto nakita ko na. credit na lang doon sa Innova tsikoteer na nag-upload can't find his/her handle here.
ImageShack Album - 10 images
Sorry wala eh, but you can access it if you remove the rear bumper passenger side, natatakpan lang siya ng bumper. Thick rubberize sheet lang yung cover ng flaps opening. Some of the tsikoteers here permanently closed it with duct tape but the downside is doors will be slightly harder to close due to pressure displacement.
Function nung flaps cover is cabin pressure stabilizer, pag naka-on ang rear aircon ay sumasara yung flaps dahil pahigop yung blower. pag may pinto na isinara bubuka ng knoti yung flaps cover para ma-displace yung excess cabin pressure.
Actually matibay yung stock 1SMF na low maintenance, but after 4 years pinalitan ko na even malakas pa siya, ayaw ko kasi abutan sa kalye with dead batterysulit na sa akin ang 4 years. Sa mga old cars ko umaabot ng 6 years until its totally dead pero mahirap kasi pag inabutan ka sa kalye
All stock pa rin accessories ko, I just replace it with 3SMF dahil konti lang naman difference nila sa price.
^thanks sa mga inputs niyo sir..try ko pa check na lang battery ko po.. maintenance free din po yun stock ng battery ng E innova sir...
mga Bosing ilang taon po ba bago mag palit ng Battery?
got my innova last Dec 08, 2008 'till now po Stock pa rin gamit ko.
per Service Advisor (last change oil ko) dapat na raw palitan kasi ginagamit daw sasakyan kaya daw nagkakarga na lang 'yung Battery. GOD Bless!!!
Thank you po,
GOD Bless!
Yan ba talaga yung sinabi niya o yan lang pagkakaalala mo?
Malabo kasi yung reason nung service advisor.
Usually, ang battery magpapakita ng signs bago bumigay. Isa jan start mo ng makina, mabagal na ang redondo o ikot ng makina. Pwede pa mag-start pero since mahina na battery, parang hirap ang starter.
Anyway, sulit na sulit na yung battery mo kung dec 2008 mo pa siya gingagamit. Ako by experience 2 to 3 years lang papalitan na.
My stock battery is still ok. turning 5 years this july. alaga lang sa distilled water.battery is primarily used sa pag start ng engine. once engine is on , alternator na ang gumagana.
lucky the guys whose batteries gave warning signs before dying completely.
in my experience, my batteries die suddenly. as in, good as new yesterday, dead as a doornail this morning.
with diesel engines, this means you probably won't be able to start the vehicle unless you have very strong na tagatulak (yes, you can push-start a diesel even if cold! medyo matagal lang nga..). in my case, i have a battery charger at home. when it happens, i just give it a booster charge. once started, i head to the store and buy a new battery.
gas engines, especially those with EFI, are easier to push-start even with very weak battery.
a female friend who knows next to nothing about cars, does not like to take chances. she replaces her battery every 2 years, regardless.
the batteries i use, have an 18 month guarantee. they last me at least 30 months.
your service adviser probably just wants to save you the horror of dead battery syndrome. it's your choice if you want to play battery roulette or not.
if your vehicle is an automatic, i recommend you replace your battery at a pre-determined date, regardless; or you buy a battery charger.
sa mga battery shops ay puwedeng mapa diagnose kung ok pa ang battery.
iyon sa avanza ng nagpa regular PMS sa toyota shaw, sinabihan ako na mahina na ang oem battery ko. kaso ok naman ang busina at start ng makina. pero after 2 months, umaga, weekday, ayaw na mag start.
For a 12V battery ano ba ang minimum reading sa voltmeter to be considered for replacement na?
