This is the cycle that is stated in the manual and as recommended by dealers.
Note: If you will do your maintenance at the dealer just say to the Service Advisor that you don't like those engine treatment or decarbonizing ek ek, it will cost you too much money. Just do a regular change oil PMS. You can also do PMS at any gasoline stations and follow what I listed below and you'll save around 40-60% cost than doing it at the dealer.
EVERY 5K KMS:
Change oil and filter (for mineral oil)
Change fuel filter element ( due to bad quality diesel we have, cost around P400 only)
Check fluid levels for brake, coolant and power steering fluids.
Check brake pad thickness.
EVERY 40K Kms ODO reading you will
need to change all lubricants and coolants.
engine oil
transmission oil.
rear differential oil
radiator coolant
brake/clutch fluid
fuel filter
air filter
engine oil filter
cabin filter
For checking:
check brake pads thickness
check all shock absorbers
check all light bulbs
Hope this helps and safe driving
