salamat sir sa info,
hirap dun talaga magpapakabit ehhehe hirap sumugal naman
hehe.. suggestion ko lang sir.. kung ako sa inyu sa casa nalang kayu mag pakabit
wala ng ma void na warranty..
sure yung pag kakagawa kasi sarili nilang product yun ..)
ma void lang naman warranty kung yung accessory na kinabit mo ang dahilan ng problem hehe.
ako nga may rear spoiler with LED brake lights, di void warranty ko, eh yung wire ng spoiler naka tap sa brake lights. :D
sakin yun hood moulding at likod (backdoor handle?) lang naka colorkeyed... side mirror at door handles naka chrome sakin.. pa colorkeyed ko sana door handles ko kaso iniisip ko lagi hinahawakan yun at magagasgasan lang lalo na pag may magbubukas at naka singsing.. pag chrome door handle madali lang naman palitan kesa sa pa repaint.. opinyon ko lang po ito sir ah![]()
merong tig 5k na HID projector retrofit kit with angel eyes yun na lang bilhin mo sir.. kaso permanent na yun kasi papaluwangin yun headlight mo para mag fit yun projector...
pag ayaw mo naman naka projector..ang kunin mo na HID kit yun may takip na chrome sa Hi/Lo bulb niya para ma lessen yun glare niya at di kalat.. eto gamit ko ngayon at tinest namin sa daan 4times ok naman wala naman nagrereklamo na kasalubong o nagsisignal na nasisilaw sila...
Hi guys. Just got a second hand innova last week. I noticed that the vehicle is slightly tilted lower to the left (driver side). At first I thought something heavy was just loaded on that side. But after clearing out all the items inside, the vehicle is still tilted.
I took it to a Yokohama shop in Binan to have it checked. The mechanic's recommendation is to replace both front shocks because it already has leaks, and that it's probably causing the tilting. Bumagsak na daw siguro yung shock kase may tagas na. So we went on with the replacement for P3,000+ (for each shock absorber).
But after installation, the car is still tilting down to the driver's side. They can't seem to figure out what's wrong with the car. They said I have to bring the car to the casa so they can check the whole body's placement on the chassis.
Has anyone experienced this? What could possibly cause the tilting?
Need help on this. Thanks!
Mga boss tanong lang po kung normal lang po ba na walang wheel weight (yun pong parang nakaipit or nakadikit lang dun sa labas ng mags na tingga) ang isang gulong (right side rear)? Ako po kasi naglagay ng tire black kanina at dun ko lang napansin na wala, nung december ko po nakuha innova g ko sa toyota pasig, nag tanong na po ako sa sa ko kung nag tire rotation na, ang sabi sakin sa 10k pms pa daw ang rotate.. TIA mga boss!
Normally, ang wheel-balancing ay ang mga gulong lang sa unahan... That's probably the reason why wala kang nakikitang tingga sa rear wheels mo bro...
Did I read it right na ang kanang gulong sa hulihan ay wala, at ang kaliwang gulong sa hulihan ay mayroon?
15.7K:lalala:
Possibilities:
1. Puedeng yung big rubber dumper between the chassis and the body, usually the driver side wears out early. Some remedy this by inserting another layer of hard rubber bushing or a much taller rubber bushing.
2. If front lang ang di pantay puedeng yung upper ball joint lang. Did they inspect the ball joints, tire rod end joint, etc.. these joints are more important to be replaced when worn out rather than the shock absorbers.
3. If sa rear, check the chassis/body rubber dumpers.
