a cheaper alternative, is to get replacement blades alone (blades only; not including the blade holders that connect to the pivots).. but you will probably have to adjust your current blade holders so the replacement blades will slide thru easily. it takes some amount of knowledgeability, but once done, all you have to do is to slip out the old and slip in the new..
these blades cost up to 130 kesos a pair.. they're so cheap you can replace them every year.
Casa sells the rubber blades only. Its a little more expensive than the price you quoted but the beauty is it's an exact length. I looked for one in car shops but I will have to cut to exact length which will not be good for that blade because of the plastic lining. On the original casa rubber blade, you have to remove the two stainless steel strips from the old one and slip it into the new blades. Installing the new blades is a bit tricky though but can be done with some common sense and a bit of DIY experience.
di ko po alam kung ok lang dito magtanong... sencia na po.. baka may alam po kau na nagbebenta ng innova G 2005 model.. automatic... in condition po... gusto ko po sana bili once na makakita po ako ng good unit... maraming salamat po at sencia na po kung bawal magtanong sa thread na ito.. salamat po uli...
mga sir may mga nagamit ba sa inyo ng premium diesel fuel (petron turbo/vpower diesel) sa innova nyo? gusto ko lang malaman kung may improvement ba talaga sa performance and FC. And, mas malinis ba to kesa sa regular na diesel? plan ko kasi mag switch from regular diesel to premium diesel.
Nag try ako nito nuong sumabak ako sa long driving sa province at sa tingin ko wala naman difference sa FC pero may very slight improvment ako naramdaman sa hatak sa hills compare sa regular diesel (petron). Kung sa linis ang pag uusapan AFAIK parehas lang sila. Mas maigi pa ata ung EURO 3 sa seoil / unioil (not sure kung nag bebenta pa sila) compare sa big 3.
