Results 15,001 to 15,010 of 15485
- Sep 2006
- 2,746
July 27th, 2022 08:14 PM #15001
- Jun 2005
- 3,774
July 27th, 2022 09:58 PM #15002Haha ginagago ka lang nyan. Hindi naman sa sta rosa ginagawa body repair. Malamang ipapagawa sa kanto kanto lang tapos gagawin service oto mo
Sent from my 2107113SG using Tsikot Forums mobile app
- Oct 2013
- 2,537
July 27th, 2022 10:39 PM #15003
- 54,206
July 27th, 2022 11:21 PM #15004
July 28th, 2022 08:05 AM #15005
sabihin mo.. kunin nila yung parts sa sta. rosa at dalhin sa casa.. pag nasa casa na tsaka mo ipapasok for repair.. replace bumper without repaint kaya nang isang araw yan.. hihintayin mo kamo..
- Oct 2013
- 2,537
July 28th, 2022 11:41 AM #15006
- Apr 2010
- 742
July 31st, 2022 08:25 PM #150072KD. anyone can ID yung noise? click for video. suspetsa ko alternator bearing or pulley?
checked:
- fan belt tight. saka hindi slipping kasi it does not sound like the belt.
- clutch fan pag inikot wala naman ingay.
- no alternator idiot light, or CEL.
- di galing sa compressor.
naiwan ko tools wala akong pang baklas...
- 54,206
July 31st, 2022 08:46 PM #15008i suspect, "a bearing".
my main suspect is alternator bearing, siguro.
i already had two experiences at alternator bearing failure.,.
both times, my symptom was "dead battery".
but i confess, i never checked for strange sounds.
squirt some grease into the other bearing and see if the sound disappears. if it does, then it's the bearing.
careful not to contaminate the belt.
good luck.
we await feedback.
errr,
does the sound disappear when the aircon compressor is turned on?Last edited by dr. d; July 31st, 2022 at 08:52 PM.
- Apr 2010
- 742
August 1st, 2022 07:13 PM #15009^ nag isolate ako ng AC doc and pinatay ko pero meron pa din...
nag scout ako different shops in person and thru phone. sa rey's and yock's around 5k or so yung pulley with labor. hindi pa daw original part yun pero matibay naman daw.
nakahanap ako malapit sa amin 3500 all in. original part daw. pulley is in a toyota box, and the part looks similar sa nakakabit na sira. saglit lang less than 30mins. di ko na tinawaran mahirap buhay ngayon. wala nang ingay ngayon, pinacheck ko na din charging ok pa naman.
sakit daw ng toyota vehicles ito with a similar platform and generation (fort/hilux/hiace) per tech. hindi daw replaceable yung bearing sa loob and buong pulley talaga palit.
then sinabi niya sa akin na mahina na daw clutch fan. sabi ko kung mag check ako bago mag start nilalaro ko yan kung may resistance, and di naman ako nagooverheat kahit traffic. pinakita niya na madali nga pigilan yung fan gamit kamay niya and basahan.
kaya pala siguro pansin ko matagal mag automatic compressor pag super traffic. sa ibang araw ko na lang pagawa kako. pinapabili niya ako ng 4 na silicon(e?) tubes. parang nadadamihan ako. sa mga nagpa refill ng silicone, ilang tubes (or in milliliters ba) ang ginamit niyo?
August 3rd, 2022 02:59 PM #15010
Gas up last night for a full tank and I noticed earlier while driving it sounds like a bottle of water whenever I step on the brakes. I check the compartment and at the back of the vehicle and I found none. Could this be fuel inside the tank that Im hearing?
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
