Results 14,901 to 14,910 of 15330
February 19th, 2022 04:59 PM #14901
So far since 2017 and after 106K odo, ours never needed wheel alignment, very slightly off-center nga lang steering wheel so wala rin problema sa controls while cruising.
Balasubas pa magpatakbo si father-in-law dati kasi gamit sa grab bago nagpandemic.
Dapat siguro di na lang kalikutin kapag wala naman problema.
Sent from my SM-G991B using Tsikot Forums mobile app
- Nov 2011
- 473
February 19th, 2022 05:25 PM #14902
February 19th, 2022 10:27 PM #14903
Yup, almost 1.2M na yata base trim ni Innova this year. Would be very disheartening if the moment you fetch your brand new car eh parang automous car agad ang dating
Incorrect alignment will take a toll on tires for sure, but that may also cause premature wear on related suspension parts.
- 52,731
February 19th, 2022 10:36 PM #14904
February 20th, 2022 01:25 PM #14905
Way back when i had my 1st gen sportage, tires still look new. Never thought I needed new tires. Pero may bukol pala. At high speed di halata, pero at walking speed kumikimbot [emoji1787]
But that's different kung kumakabig. Like doc said, baka tires are skewed na. Usual issue ng goodyear before, at least sa mga kakilala ko.
- Dec 2019
- 2,072
February 20th, 2022 06:38 PM #14906Ok na ba yung mga bagong batches ng goodyears ngayon?
Sent from my SM-N970F using Tsikot Forums mobile app
- 52,731
February 20th, 2022 07:22 PM #14907
- Dec 2019
- 2,072
February 20th, 2022 08:31 PM #14908Even today a lot of vehicle owners switched to yokohama specially the bluearth es32. Very common on sedans, innovas and avanzas. Other gen1 innova owners stick with the factory spec aspec a300s.
Champiros are gt radials right? Indonesian made? Im not sure..
February 20th, 2022 09:26 PM #14909
Per GT Radial's website, Champiro is theirs, which under the series have various models also.
Anyway, have not heard the same issues with Goodyear since. Have used Yokos before (no issues experienced, except medyo pricey) as well as a few Chinese brands, Runway, Goodride, Comforser, Westlake. When it's time to patch them Chinese rubbers, noticed that they have weak/soft sidewalls. I don't know, I just thought they were.
Now both our cars are on Achilles 122, Indonesian-made. Good so far. However, they tend to slip more in wet conditions. Gives me more reason to back off the pedal when rain starts to drop
February 22nd, 2022 10:59 AM #14910
Have you replaced your map gas filter or could this be just cleaned?
high idle RPM at engine start
