Results 14,961 to 14,970 of 15329
June 20th, 2022 02:04 PM #14961
- Oct 2013
- 2,537
June 20th, 2022 10:44 PM #14962
June 21st, 2022 02:01 PM #14963
- Dec 2019
- 2,072
June 22nd, 2022 11:42 PM #14964How much yung conversion sa bagong facelift?
Sent from my SM-N970F using Tsikot Forums mobile app
- 52,731
June 22nd, 2022 11:49 PM #14965that's why it's called a facelift, sir.
the bony structure underneath is the same,
while the overlying skin and soft tissues are manipulated.
that way,
owners of older models who do not have the wherewithal to purchase new cars, may avail of facelift kits to youngify their old bones....
think of the additional money the manufacturer will rake in!
so, is a facelift worth it?
it always depends on one's point of view...
personally,
i prefer stock original.Last edited by dr. d; June 22nd, 2022 at 11:53 PM.
- Aug 2013
- 262
June 23rd, 2022 07:54 AM #14966
- Apr 2010
- 739
July 4th, 2022 10:41 AM #149672KD. nagpa full tank ako. i always turn off the engine and remove the key sa cylinder when i do gas up.
nung nag start, the needle didn't moved at all (it was 3/4 before). pati yung range km indicator hindi tumaas. i tried restarting a few times pero ganun pa din.
weirded out, umuwi muna ako. tumaas naman sa F pero soooooobrang bagal, like mga 1-2KM muna bago mag F.
may lakad ako later that day and uneventful naman, pero the range km indicator hindi pa rin tumaas. bumababa just like driving it normally.
pag uwi ko, i decided na tanggalin yung negative battery terminal overnight to clear any electrical gremlins. pag start ko ngayong umaga, bumalik na sa 530KM yung range.
ngayon observing muna kung accurate pa din yung gauge, monitor na lang palagi sa trip meter versus yung estimated range when i fill up.
may naka experience na nito sa inyo?
- 52,731
July 4th, 2022 10:52 AM #14968we have three innovae.
their fuel gauge needles do take a long time to move, after re-fueling, even when new.
i don't pay attention to their slow rise to power, anymore. they do get there, eventually.
the E variant has only two ordinary trip counters, and one odometer.
the G variant has trip counter, km/li, range, temp, etc.
i zero them after re-fueling.
one of the cars, however, developed an issue that i have not been able to fix.
the highest the fuel needle can go, is 3/4, even at uma-apaw na full tank.
but the empty-indicator needle position, has also gone down about 1/4 lower than usual.
i just learned to adjust my feelings about it.
the low-fuel light is powered by another circuit, i think, and still functions as per usual.Last edited by dr. d; July 4th, 2022 at 11:59 AM.
July 4th, 2022 02:26 PM #14969
That's normal.
A bit of history: Analog fuel gauges of yesteryears were directly hooked up as a discrete circuit. That means, the gauge and the fuel sender (the float inside the tank) are hooked up directly. When the float goes up, the gauge needle goes up, almost instantaneously. The problem is, when fuel sloshes around inside the tank or if you drive up or downhill, the float tends to jump around, which can lead to the fuel gauge going all over the place. The solution at the time was simply to incorporate a damping effect on the gauge. This slowed down the gauge needle so it doesn't mirror what the float is doing inside the tank in real time.
Today, fuel gauges are controlled electronically. Meaning, there's no direct connection between the fuel sender and the gauge. The fuel sender sends its values to the ECU and the ECU tells the fuel gauge how much fuel is in the tank. It also runs the display on the trip computers to show your range, among other things. The physical dampening is no longer with the gauge needle.... this is now done by the computer.
If you filled up your fuel tank while the engine is running, the computer will sense that the float is rising consistently, and it will tell the gauge to move up in near real time. But if you turned off the engine at say, half a tank (the last fuel quantity the computer saw before going to sleep), then you gave it a full tank, then restart the engine, suddenly the computer will see that the tank went from half to full. It will initially see it as an error and keep the needle pointing at half-tank. But if that level remains consistent (which it will be after a fill-up), the computer will decide that it's not an error and will gradually raise the gauge needle, albeit slowly due to electronic dampening and averaging, and will eventually give you the correct fuel readout after some time.Last edited by oj88; July 4th, 2022 at 02:38 PM.
- Apr 2010
- 739
July 4th, 2022 04:47 PM #14970i disagree na it's normal, ever since i am fueling it up na tanggal susi, when it is filled up palo agad sa full when i turn it on. reflect din agad yung range km indicator.
same behavior with the 1GD na palo din agad pati range. ngayon ko lang naexperience ito.
can't short the float to test kasi walang access sa pump from inside the cabin, baba fuel tank agad.
109,606 vehicles were sold in the first quarter of 2024 | TopGear PH
Car Sales Data (2024)
