Page 1274 of 1549 FirstFirst ... 117412241264127012711272127312741275127612771278128413241374 ... LastLast
Results 12,731 to 12,740 of 15485
    Apr 2017
    #12731
    Mga Sir, tanong ko lang, mga ilang liters na ;ang usually ang natitira sa tanke kung umilaw na yung "gas light" sa mga 2015 na Innova? At gaano nga ba katipid ang mga 2015 Innova 2.5e M/T?
    5liters
    Apr 2017
    #12733
    5liters
    So kaya pa pala 35-45km...
    Apr 2009
    #12734
    Quote Originally Posted by Terrence View Post
    Nag canvass po ako ang price ng expansion valve and dryer P850.00 each. siguro nga kamo ganon na lang, kapag totally nagloko na yung aircon ko saka ko na lang ipagawa at this point nagagamit pa naman. thanks sir.
    Kung tama diagnosis, replace the expansion valve IF barado talaga. Otherwise, expansion valves can be reused. Driers, on the other hand, should be replaced everytime lilinisin aircon system. Also, check for worn out O-rings sa mga fittings, better to have them replaced kapag nagpalinis ka. I had encountered such problem nun nilinis yung aircon ng innova ko last November. Nawala lamig after a week, they had to dismantle the whole system again to look for the leak, It turned out mali yung nailagay na size ng O-ring sa fitting on the rear.
    HTH.
    Apr 2017
    #12735
    Hello Guys! is there someone who encounter this kind of problem about sa front wheel.my 4years old innova was sobrang init ng front na gulong after ko gamtin yong sasakyan nagrun ako ng mga 25-30km ,sobrang init ng harap ng gulong ko unlyk sa rear wheel di nman ganun kainit.pag nananakbo naman ako ok naman. ung brakepad i think is ok kasi wala namang nasipol. di kami natuloy biyahe paprovince kasi im so worried sa situation ng front wheel lalot malayuang biyahe pa at pabundok.
    #12736
    Quote Originally Posted by mr.pantherQ View Post
    jack up the front end of the vehicle, and spin the tires. there is normally only a teeney bit of resistance. both left and right side wheels should have equal resistance. i am sorry, but i can not quantify it better. one has to experience it firsthand.
    then, with the car still jacked up, start the engine and step on the brakes and release it. have a second person inspect the tires and spin them by hand, after releasing the brake pedal. see if there is increased resistance ("dragging").
    if the wheels drag, then bring the car to the shop.
    normally, because the fronts are disk brakes, the pads are always lightly touching the disks. this creates some heat. the rule of thumb is, "if the wheels, after a long-ish drive, feel uncomfortably hot, then something is wrong, like dragging brakes".
    #12737
    Both front wheels?
    And I assume when you stated "sobrang init" you meant the rim/s is/are as hot as a clothes' iron....
    You need to have them checked. Good decision not to take it on a trip...
    #12738
    tekateka...
    baka naman sa tagaytagay highlands..?
    i-init talaga ang brakes doon. at puedeng mangangamoy ang friction pads.
    #12739
    I experienced the same when I went to Crosswinds in Tagaytay..nangamoy at sobrang init nung preno, hindi ko lang matandaan if I shifted to d2 prior. I was not using an Innova then though.
    Sent from my SM-G610Y using Tapatalk
    #12740
    The brakes on the Innova are small to begin with. And the oem Yokohamas being a hard compound makes the brakes work harder. Stickier tires will help. On long downhill stretches it pays to use engine braking to lessen stress on the brakes.
Toyota Innova Owners & Discussions [continued 3]
