Results 12,751 to 12,760 of 15485
- Jan 2017
- 11
April 19th, 2017 12:47 PM #12751Gandang araw mga mam/sir.
Naka 1k na po ung innova namin, ano ano bang dapat ipa-check up sa dealer? Sabi kasi sakin nung mga napag tanungan ko na, wag daw muna synthetic oil ang gamitin since bago pa lang. Double check ko din daw kung ano ung gagawin kasi baka mapagastos daw ako na di naman kaylangan.
Eto ung mga nasabing ipacheck ko pag punta ko daw sa dealer
change oil (wag synthetic, kaso di ko alam ano ung standard)
change oil filter
tires
brakes
Salamat po sa magbibigay ng inputs
- Jul 2016
- 1,178
April 19th, 2017 01:44 PM #12752Mineral oil pag ayaw mo synthetic mas mura. Pag wala naman problem sa tire and breaks mo wag mo muna pagalaw. 2 weeks ago nag pa 1k pms din ako change oil and filter lang. May separate thread yata sir para sa new innova dun ka na lang mag post next time. Thanks
Sent from my SM-J500G using Tsikot Forums mobile app
- Feb 2006
- 108
April 19th, 2017 02:14 PM #12753ask ko lang po kung ano pwede ipalagay na gear oil at power steering fluid sa 2010 innova diesel po nasa 80,000km na rin po kasi yun sasakyan namin ano po okey na ilagay thanks in advance po
- Mar 2013
- 220
April 19th, 2017 03:29 PM #12754
- Feb 2006
- 108
April 19th, 2017 03:50 PM #12755
- Mar 2013
- 220
April 19th, 2017 04:05 PM #12756
- Jan 2017
- 11
April 20th, 2017 03:26 PM #12757
- Apr 2017
- 10
April 24th, 2017 02:29 PM #12758Good day! now my front wheel is ok , so far di na sya ganun kainit. after ko makarating ng house inoff ko na ung engine close door pero ung susi nakapasok parin, panay alarm yung sa dashpanel ba yun dko lam bat nagkaganun tot tot tot tot na continue cxa.tas pag tinanggal ko na ung susi nawawala naman,1's na ipasok ko lang ung susi not turning on.panay alarm lang cxa.this is not a normal sa car ko 1st tym lng talaga anu kaya dahilan nun bat nagkaganun?
- 54,234
April 24th, 2017 04:39 PM #12759maybe your alarm is needing replacement. or you have a grounded sensor somewhere.
when you start the engine, the alarm naturally is turned off, and it does not bother you with its bells and sounds.
pa-tingin nyo po, at baka ma-ubos ang baterya isang araw at hindi nyo na siya ma-start.
- Aug 2008
- 164
April 25th, 2017 09:36 PM #12760Ask ko lang po kayo guys, nagpalagay ako silicon sa fan blade ng innova ko kasi mahina na daw ang buga ng hangin, pero after malagyan ng silicon indeed lumakas ang buga ng hangin at idle. But na obserbahan ko kapag tumatakbo ng mabilis may malakas na humming sound coming from fan blade dati wala naman ako naririnig na ganun. May particular brand ba ng silicon na dapat for innova. Appreciate ur replies. Tnx
Is it true na may recall ang yaris cross hev recently regarding sunroof issue? Lol.
China cars
