Page 1324 of 1549 FirstFirst ... 122412741314132013211322132313241325132613271328133413741424 ... LastLast
Results 13,231 to 13,240 of 15485
    Oct 2009
    #13231
    Saan po ba pwed makabili ng Engine cover para sa 2018 J Model at magkano?
    Aug 2018
    #13232
    if the level dropped 1 cm and did not go down anymore after that, then i wouldn't be worried.
    but if the level keeps dropping over the days, then something is wrong. typical innova coolant levels remain stable for many months to over a year.
    my guesses would be:
    1. you are overheating. perhaps your radiator is so dirty (on the outside, as well as inside?), it can not radiate heat anymore. and how's your fan?
    2. leak.
    Thanks for the advice! I actually kept note of its level yesterday and today and it looks like it's stabilizing now. I guess it takes a few days for the true level to show up? Some of the coolant was drained kasi when I brought it for repairs about 2 weeks ago so I topped up. But I'll continue to check it because if it goes down below L again I'm taking it to the shop.
    Jun 2018
    #13233
    San po kaya pede e download pdf ng toyota manual?
    Thanks
    Jun 2005
    #13234
    Quote Originally Posted by eeyan55 View Post
    Alam ko nasa 5500 bentahan neto sa mga online seller
    Sent from my MI MAX 2 using Tapatalk
    #13235
    errr... what does it do, po?
    what advantage does it confer the vehicle?
    mine does not have, and it doesn't seem to suffer the worse without it.
    Jan 2013
    #13236
    Are you referring to engine under cover? Sa casa ako bumili nyan pagka alala ko 6500 bili ko sa casa. Malaking tulong yan para hindi dumumi yung ilalim ng engine bay lalo na kung maputik dinadaanan mo lagi.
    May 2015
    #13237
    For the 4th time. Pundi nanaman yung left break light namin. Yung right going strong pa. Sinong naka remedyo na sa inyo ng ganitong problem? Park light was good dun sa mga napunding breaklight bulb sa left.
    Sent from my Redmi Note 5 using Tapatalk
    #13238
    Quote Originally Posted by johann123 View Post
    check:
    loose mounting of the socket, the housing. baka may dumi sa pagitan ng housing and the metal.
    dirty contacts?
    correct bulb specification?
    May 2015
    #13239
    check:
    dirty contacts?
    Okey naman housing dr. d. Wala namang contacting between the metal sa loob. Yes right bulb po. Tomorrow i will upload pics.. Pansin ko na din sa ibang innova to eh 2015 and below. Pero tumagal naman ng 8 months yung bulb na napundi.
    #13240
    8 months only?
    perhaps you should try another brand of bulb.
Toyota Innova Owners & Discussions [continued 3]
