Results 14,951 to 14,960 of 15344
June 10th, 2022 04:39 PM #14951
June 10th, 2022 04:49 PM #14952
It's still like that.... when it's armed and you open any of the doors, the alarm will sound through the main horns.
AFAIK, the single buzzer on the side is used for two things.... the answer-back feature as I've detailed above, and as a sort of "door-minder" when you're trying to arm the vehicle with the remote and any of the doors are still open or ajar.
June 12th, 2022 11:05 AM #14953
June 12th, 2022 06:14 PM #14954
Here's an addendum to the instructions above for Step 5:
Both Options A and B I've discussed in my original post above but I've summarized them below for brevity. I've added C which disables all arm/disarm feedback... for the Ninjas among you.
Option A - Flashing turn signals ENABLED | Answer-back DISABLED (Default):
Lock, Unlock, Lock, Unlock
Option B - Flashing turn signals ENABLED | Answer-back ENABLED:
Lock, Unlock, Lock, Lock, Unlock
Option C - Flashing turn signals DISABLED | Answer-back DISABLED:
Lock, Unlock, Lock, Lock, Lock, UnlockLast edited by oj88; June 12th, 2022 at 06:19 PM.
- Aug 2013
- 262
June 13th, 2022 08:20 AM #14955
June 13th, 2022 08:45 AM #14956
Yep, you need to do it in the proper order and with the right timing. I guess they did that to make it harder for people to enter that mode by accident.
I also considered changing the transducer. Anyway, any 12V sounder should work. But I don't use it enough to be bothersome.
- Oct 2013
- 2,537
June 20th, 2022 11:59 AM #14957pinag loloko tayo ni toyota sa facelift, di man lang binago yung posisyon ng turnilyo
June 20th, 2022 12:35 PM #14958
That's typically how the concept of MMCs and facelifts work. It's essentially a marketing ploy to revitalize a car model (ie. same generation).
Parts are often interchangeable but sometimes, cut-outs on adjacent metal parts like the hood, trunk, etc. may not work with the newer facelift parts.
- Jan 2008
- 4,726
June 20th, 2022 01:26 PM #14959Parang nag pa banat lang ng mukha.. hehe
Some models nga require the fender and hood replacement.. pero toyota palit bumper lang talaga
June 20th, 2022 02:02 PM #14960
It will depend on the specific vehicle/battery designs on making it feasible but some(Tesla and...
Mitsubishi Xforce
