Page 1446 of 1549 FirstFirst ... 134613961436144214431444144514461447144814491450145614961546 ... LastLast
Results 14,451 to 14,460 of 15485
    Feb 2019
    #14451
    Quote Originally Posted by Lakwatsero View Post
    Misalignment will cause kabig, out of balance will cause vibration.
    Check your tire pressure first and drive on a level road, if it persists, have it balanced and aligned.
    My tire pressure is okay. I will just find a level road and see if problem still persist thanks sir.
    Feb 2019
    #14452
    Has anyone tried using this air filter brand or JGC replacement brand? Is quality good? Saw the item on shopee and they are relatively cheap compared to oem or fleetmax.
    May 2016
    #14453
    Quick google search led me to a filterpro.com which supplies industrial-grade filters, not really automotive filters.
    If you're looking to save, might want to try JS Asakashi. Probably close to that in price. You can check their parts catalogue online for your unit.
    #14454
    While i was driving earlier I noticed when my hands aren't in the steering wheel, the steering wheel would wiggle a bit left and right in quick sequence is this normal?
    if it occurs at a certain speed only and not at all speeds,
    your tires may be out of round.
    Feb 2019
    #14455
    Yes I have seen JS Asakashi too in shopee and price not that much difference compared to filterpro.
    Feb 2019
    #14456
    I gas up last night and my fc is at 6.6km/li city driving 40-60km/hr on average. I need to replaced the air filter and see if my fc improves. Aside from JS Asakashi any recommended replacement brand?
    #14457
    Wix is pretty good. OEM quality at a lower price. Fleetmax I've tried before and it is a little more restrictive vs OEM.
    If you are using 40 wt oil you could also try switching to 30 wt if the manual allows it. Might bump your fuel mileage a bit more.
    Feb 2019
    #14458
    How much is the oem air filter around Php1200? I have seen both wix and fleetmax in Shopee selling for Php700-800 and other replacement brand JS Asakashi Filterpro, JGC selling much lower for around Php400-500. What do u mean by more restrictive? I have been using 15W-40 ever since and this is D4-D I also plan to switch to 30 before but I still stick with 40 probably if my engine is gasoline I can switch to 30.
    Jan 2020
    #14459
    Quote Originally Posted by johann123 View Post
    Baka merong gusto sa inyo oh lalo na sa mga naka J and E variant na innova [emoji4]
    Sent from my Redmi Note 5 using Tapatalk
    Hi
    Would this still be available?
    Thank you
    Hi
    Thank you
    #14460
    the engine cover used to be standard issue in the previous gen innova.
    as was the nice ashtray, in the first offerings...
    the times.. the times..
Toyota Innova Owners & Discussions [continued 3]
