Page 1469 of 1549 FirstFirst ... 13691419145914651466146714681469147014711472147314791519 ... LastLast
Results 14,681 to 14,690 of 15485
    #14681
    Re replacement bulbs for the dash, T5, T3 i ordered assorted sets from Shopee intended for my Gen 1 Vios "sana". Since last year nasa drawer pa rin.
    better bring yours to the shop na lang doc. chill ka lang while they restore your dash lights.
    BTW, just went on a 250km loop over the weekend using the innova occasionally flooring the pedal when overtaking and on long stretches. when i went to clean the engine bay, noticed a good amount of damp oil around the inlet hose of the throttle body. it's probably normal blowby but is it excessive already? did any of you added an oil catch can to your innovas?
    Aug 2008
    #14682
    Good pm, anybody who had their aircon compressor replaced? I would like to ask how much ang original compressor? Mine is sanden ang brand.
    #14683
    Quote Originally Posted by Terrence View Post
    i do not know the cost.
    but perusing carousell, the range is 8.5K to 12.5K.
    but i am wondering,
    why you think it should be replaced?
    my compressor is over 15 years old and over 140K km old, and it still compresses fine.
    Feb 2019
    #14684
    I have it quoted before and it is around 20K afai can remember. They can check the bearing the one that spins with he serpentine belt if it is stuckup or not.
    #14685
    i imagine,
    this bearing is replace-able?
    even if some folks say it is not...?
    Feb 2019
    #14686
    i imagine,
    That im not sure of better ask a qualified mechanic.
    Aug 2008
    #14687
    my compressor is making this strange sound whenever I'm cruising at NLEX, I had it check by an aircon shop and told me that its for replacement na.
    Feb 2019
    #14688
    What kind of strange sound? How about when idle?
    Dec 2019
    #14689
    is it sounds like squeaking noises at the compressor?
    #14690
    the more strange part is that you're only having the issue while at cruising speed. one effect i had with the innova's fan clutch losing silicon fluid (at around 95K odo), is that the AC gets overly pressurized making the compressor work harder resulting for it to produce some kind of a whining noise. AC could also be low on PAG oil but the sound it made was close to low whining.
    however, when cruising, noise disappears and everything seems normal. and that was because the condenser has now more air blowing on it relieving the pressure from the compressor. may need to make sure the noise doesn't come up even while parked, whether at rev, or idle as Deestone asked earlier.
Toyota Innova Owners & Discussions [continued 3]
