Results 14,681 to 14,690 of 15485
May 11th, 2021 05:26 PM #14681
Re replacement bulbs for the dash, T5, T3 i ordered assorted sets from Shopee intended for my Gen 1 Vios "sana". Since last year nasa drawer pa rin.
better bring yours to the shop na lang doc. chill ka lang while they restore your dash lights.
BTW, just went on a 250km loop over the weekend using the innova occasionally flooring the pedal when overtaking and on long stretches. when i went to clean the engine bay, noticed a good amount of damp oil around the inlet hose of the throttle body. it's probably normal blowby but is it excessive already? did any of you added an oil catch can to your innovas?
- Aug 2008
- 164
May 20th, 2021 05:36 PM #14682Good pm, anybody who had their aircon compressor replaced? I would like to ask how much ang original compressor? Mine is sanden ang brand.
- 54,232
May 20th, 2021 07:39 PM #14683
May 21st, 2021 09:17 AM #14684
I have it quoted before and it is around 20K afai can remember. They can check the bearing the one that spins with he serpentine belt if it is stuckup or not.
- 54,232
May 21st, 2021 12:02 PM #14685
May 21st, 2021 12:41 PM #14686
That im not sure of better ask a qualified mechanic.
- Aug 2008
- 164
May 26th, 2021 12:42 PM #14687my compressor is making this strange sound whenever I'm cruising at NLEX, I had it check by an aircon shop and told me that its for replacement na.
May 26th, 2021 01:26 PM #14688
What kind of strange sound? How about when idle?
- Dec 2019
- 2,073
May 26th, 2021 01:45 PM #14689
May 26th, 2021 04:17 PM #14690
the more strange part is that you're only having the issue while at cruising speed. one effect i had with the innova's fan clutch losing silicon fluid (at around 95K odo), is that the AC gets overly pressurized making the compressor work harder resulting for it to produce some kind of a whining noise. AC could also be low on PAG oil but the sound it made was close to low whining.
however, when cruising, noise disappears and everything seems normal. and that was because the condenser has now more air blowing on it relieving the pressure from the compressor. may need to make sure the noise doesn't come up even while parked, whether at rev, or idle as Deestone asked earlier.
Getting a toyota would be ideal mostly for those looking for practicality or one who will use it...
China cars
