Page 617 of 662 FirstFirst ... 517567607613614615616617618619620621627 ... LastLast
Results 12,321 to 12,340 of 13229
    Jun 2008
    #12321
    ^Dude, try checking if the car is upright. Do so by measuring the clearance between the tire and the fender on the front wheels.
    Mar 2007
    #12322
    At last, I had the time to change the cabin filter yesterday.
    I suggest na talagang if you have the time, linisin natin. Grabe ang
    dumi na nakuha ko sa filter, 3 years na rin innova ko.
    Thanks sa steps ni Mile2 for the DIY. Malaking tulong, sarap ng
    hangin ng aircon pagmalinis ang filter.
    GLD
    Jun 2009
    #12323
    ako rin, just had my cabin filter cleaned last week. mag 1 year pa lang innova ko one June and rarely opened and windows pero grabe ang dumi.
    noticed kasi loss of cooling efficiency. grabe, anlaki ng pagbabago sa lamig ng car ngayon.
    May 2005
    #12324
    How to wash it the cabin filter? I just soak it in a soap and water solution of Perwoll or other brands overnight. The next morning, I brush it lightly with a used toothbrush. Rinse thoroughly and (optional) soak for an hour or so in water just as an extra measure against remaining soap residue.
    #12325
    paano naman sa mga model 2005? nung last pms ko sabi sa SA na isama na yung paglilinis ng aircon filter pero sabi niya mahirap daw gawin. to all owners of 2005 model anybody tried cleaning yours?
    Aug 2006
    #12326
    I think it is not advisable to wash the cabin filter since the material is so thin and only glued to cardboard like reinforced brace. I also tried washing it using mild pressurize water plus dishwashing liquid and the result is exceptionally very clean but I noticed that some glued portion got wear off, since then I only use blower/vacuum cleaner to remove dust.
    Ask your dealer for the cabin filter/door lid kit and let them install it for you since it will entail cutting of plastic lid on the blower motor housing.
    Aircon whole assembly cleaning at casa will take 2-5 days since they would dismantle the whole dashboard and the rear quarter panel sidings (rear passenger side seat removed). Parang kinatay ang itsura ng car mo pag nilinis ang aircon.
    #12327
    Innova owner here...2006 J...having problem with my suspension??....feeling ko matagtag ay may tunog sa harap parang may kumakalog specifically on my left side...already found untightened nut underneath the dashboard, the clutch pedal bracket and steering bracket...pero andun pa rin yung soung na yun lalo pag malubak....any ideas mga innova gurus?? pls help..TIA
    Aug 2006
    #12328
    Quote Originally Posted by fgmanalo View Post
    Mine was also 2006, and had my Left and Right shockz replaced sometime 2008 and 2009 respectively. My wild guess was that you probably had a busted shock absorber as well.
    You can bring it to your Toyota dealer for servicing or you can bring it to some reputable under chassis repair shop, its your choice.
    It would probably some other parts like wear out rubber bushing or tire rod end or rack end. It would need a car lifter to fully diagnose your front suspension parts anyway.
    Jan 2010
    #12329
    I was surprised that my my bnew innova has 40psi for all tires...What is the psi have you been using? i used 30 but when you look at it, it looks like a flat tire ... hmmm
    Jun 2006
    #12330
    yap, at 30 psi, it looks flat, but thats what stated at the driver side door pillar. Anything above 35, natatalbugan na ko.
    Jul 2006
    #12331
    Quote Originally Posted by desertfox615 View Post
    Tinry ko to, pero parang nahihirapan ako sa pagtanggal ng glove box matigas ba talaga yun? Natatakot ako pilitin baka mabiyak.
    Jul 2006
    #12332
    Been to Big Bert's last week para mapa- new car paint protect ko Innova. May gamit silang flourescent to check the paint. Nakita sa paint ko dami na water marks. Normal ba to sa brand new innova? Maybe kasi matagal na nakabilad sa planta?
    #12333
    crossedge
    anu ung new car paint protection?? he he!!!
    curios lang..
    Jun 2009
    #12334
    crossedge,
    matigas talaga. kala ko nga magcacrack e. takot din ako. pero ayos naman. wala nasira sa glove box ko.
    ako, di ko binasa un filter. baka kasi mapunit. tinaktak ko lang.mas maganda kung may blower ka para talagang tanggal lahat ng dumi.
    #12335
    Guys ilang months ba dapat bago linisin ang aircon filter???
    Mine 3 months old na.advisable ba na gawin ko ung paglinis niyo!
    Jan 2010
    #12336
    [quote=Mile2;1444576]I think it is not advisable to wash the cabin filter since the material is so thin and only glued to cardboard like reinforced brace. I also tried washing it using mild pressurize water plus dishwashing liquid and the result is exceptionally very clean but I noticed that some glued portion got wear off, since then I only use blower/vacuum cleaner to remove dust.
    Mr. Mile, un bang rear aircon meron ding filter like the cabin front filter? Baka lang kasi nakaconcentrate ako sa paglilinis ng cabin filter and then meron pa palang isa sa likod.
    Aug 2006
    #12337
    [quote=brenz;1445107]
    Quote Originally Posted by Mile2 View Post
    Di ko alam kung meron sa likod, takot akong baklasin ang rear aircon blower ang dami kasing kailangan baklasin including rear seats and sidings baka hindi ko maibalik ng maganda pag binaklas ko hehehe Baka kulang isang araw para mabaklas ko at maibalik
    Jul 2006
    #12338
    Quote Originally Posted by morlack View Post
    crossedge
    curios lang..
    Visit Big Bert's website for more information http://www.bigberts.com/services.htm
    #12339
    Thanks sir Mile2..will try that....but i dont see any leak from my shocks.....is that a sign that my shocks are not in good condition even if there's no leak??....
    Aug 2006
    #12340
    You will need to fully steer the tire on one side to peak at the shocks and look for sign of wet and oily surface.
    It would be a probability that you missed noticing the leak and it has dried up, but this is just my assumption though. Like I mentioned it would be best to diagnose that rattling sound using car lifter.
    Mine was already diagnosed with weak rack ends and tire rod ends and was quoted P7800 including labor at Gomags Trading, Evangelista St. Pasay.
Toyota Innova Owners & Discussions [ARCHIVED]
