Page 409 of 662 FirstFirst ... 309359399405406407408409410411412413419459509 ... LastLast
Results 8,161 to 8,180 of 13229
    Aug 2006
    #8161
    Quote Originally Posted by Turbocharger View Post
    To all Innova owners,
    Have you check the condition of your center pillar rubber? These are the rubbers on the side doors. Yung sa akin kasi bumubuka kaya try ko claim sa warranty it's a good thing inayos naman nila. Common problem daw sa Innova yun ewan ko lang sa mga unit ninyo if the same?? FYI lang.
    Anchor-clip lang kasi yung Pillar cover and they have the tendency to get deformed if not pressed correctly, usually they would just heat it slightly and bend it to its proper alignment, additional clamp lang yung rubber molding sa gilid. You can DIY it naman
    May 2005
    #8162
    mga bossings, ask ko lang kung limited ang budget... ano mas magandang unahin?
    stepboard, foglights, or rear spoiler with 3rd brake lights?
    or baka me nagbebenta jan ng stock na alloy mags, hehehhe, yun na lang...
    thanks....
    #8163
    Quote Originally Posted by rockers_kitoy View Post
    Guys, your views and comments are very much appreciated.
    I have a 17-inch mags and I'm soliciting what are the possible tire and brand combination for such... para mas malufet tingnan ang Innova.
    I saw a Michellin brand, with specs: 225/50/R17. oks na yan?
    Thanks in advance.
    Sir, I'm also using 17" mags with tire specs 225/55/17. Medyo manipis na kasi tignan yung 50 series. Alam mo naman road condition dito sa atin.
    #8164
    Quote Originally Posted by kumagbehota View Post
    thanks....
    sir, if you are after convenience lalo na kung may kids, go for the stepboard. Mataas kasi ang Innova.
    #8165
    Does anyone know how much one of those vertical billet grills cost? I want to replace the grill on my innova if ever. Just asking since no one replied to my question in the accessories thread.
    Aug 2006
    #8166
    Quote Originally Posted by hryan09 View Post
    You can call any Toyota dealer, I saw one at Toyota Manila Bay
    Aug 2006
    #8167
    thanks....
    Go for value for money ... the step board will definitely help kids and elderly and much more it will somehow protect your running board and door panels from stone chips and road tars.
    May 2005
    #8168
    sige mukang stepboard nga kukunin ko, magkano kaya yung pinakamura pero matibay? di ko kasi makita sa threads eh.. at saang shop, thanks
    Mar 2005
    #8169
    Guys, help naman...
    I was going home last night mga 30 minutes na running yung car when I suddenly smelled something kinda burned.
    Pinakiramdaman ko muna, open and closed the windows while driving pero consistent yung burned smell.
    I looked around and turned on and off some switches and later found out that my fog lamp switch maybe the culprit. That's what I pressumed 'coz when I turned it off, the smell kinda diminished. But the switch was not that hot naman (It's a push in and out switch which lights up when activated). It was not also turning the fog lamps on and off properly for sometime.
    When I got home, I checked the engine bay, nothing smelled burned naman.
    I guess the burned smell was originating inside the car only.
    When I drove to the office this am, no burned smell naman so far.
    So I'm thinking the electricals that I use when night driving might be the reason.
    I'll test it again tonight, pagumulit...papa-check ko na.
    Anyone among you had this incident na? Mine is a "J" gas with casa installed foglamps... Thanks in advance for your inputs...
    Aug 2006
    #8170
    P5k yata ang kuha ko sa Autobacs Banawe, tawaran mo
    This is one of the accessories that will not void your warranty
    May 2005
    #8171
    dyan din sa autobacs ako nagpalagay ng mga accessories ko like side mirron protector, mudguards and side moulding, sana nga matawaran pa, hehehe, ang inuna ko hangat maari yung di affected yung warranty, except lang yung alarm ko, hehehe...
    sablay lang sa akin yung side moulding natatangal yung double sided na tape
    Jan 2008
    #8172
    Guys, magkano kuha nyo ng tirelock? At san nyo to nabili? Thanks!
    May 2005
    #8173
    spare lock boss sa banawe nag re range ng 1100 to 1500 depende sa paki usap...
    May 2007
    #8174
    yan ang karaniwang problema pag di sa casa binili ang side mouldings... me isang member din (Daryl) na yan ang reklamo sa akin nung last EB... kung anu-ano na raw tape ginamit nya pero natatanggal pa rin.
    Oct 2004
    #8175
    hi liv, pa text naman nung link ng eb natin. hindi ko kasi ma view dito sa forum di ko alam kung bakit . cell ko 09167702595.tnks
    May 2007
    #8176
    Quote Originally Posted by geo View Post
    eto po ung link sir... http://tsikot.yehey.com/forums/showt...10#post1058510
    Aug 2005
    #8177
    Quote Originally Posted by bumags View Post
    Guys, help naman...
    * bumags, the culprit is none other than the fuse of your foglamps. It is located just below the steering inside the detachable panel. See picture below:
    The fuse tends to get loose from the terminal (esp on rough roads) thus creates sparks eventually burns the plastic terminal housing. I got my fuse replaced just 3 weeks ago when I experienced same. It's ok now. Pina-secure ko lang mabuti ng plastic tie. Have yours replaced, otherwise don't use your foglamps yet until the fuses are replaced. Drive safely bro.
    Aug 2005
    #8178
    * kumagbehota, re-sticking lang with 3M moulding tape ang kailangan. Removing the side moulding is necessarry. But prior to that, stick a reference line using a masking tape on the body, para straight/aligned yung side moulding pag dinikit mo ulit yung side moulding. Remove the old double side gummed tape from the side moulding, thence cleanse the surface with alcohol. Apply a little pressure on the tape when sticking it at the back of the moulding. Patting the tape lightly with any tool helps a lot for firm adhesion. Apply alcohol as well to the surface area of the door where the side moulding is to be attached. Natanggal din yung side moulding ko noon esp dun sa area ng back fender curvature. Ngayon oks na oks na. Hope this helps.
    May 2005
    #8179
    thanks sir sa tip, hirap nga din yung sa akin eh, medjo matrabaho... ang prob ko kasi mainly sir yung side ng tape kung saan nakadikit mismo yung moulding, bumibigay sya...pero yung sa side na nakadikit sa oto nakadikit pa din...
    Aug 2005
    #8180
    Make that side of the moulding where the tape is to be fixed na rough sya by sanding. Tapos pag dinikit mo tape after applying alcohol, medyo pukpukin lightly with any tool bago i-peel off prior re-sticking to the car's body. Un lang ang ginawa ko, until now intact pa rin sya. You need to patiently remove the old tape from the car's body. Medyo matrabaho, kasi may kahirapan na tanggalin yung nasa body. Use 3M adhesive remover to remove it.
Toyota Innova Owners & Discussions [ARCHIVED]
