Results 1,071 to 1,080 of 2023
August 30th, 2006 01:53 PM #1071
August 30th, 2006 05:09 PM #1072
same experience here down south mindanao. Innova ng family friend namin,
wala pa isang buwan ayaw umandar, kaya ayun nakastambay ng isang linggo. Malayo pa naman ang casa sa amin halos 5hrs ang travel. At ang pinakamasakit pa dun, eh financing pa ang kuha nila sa sasakyan.
August 30th, 2006 05:33 PM #1073
Don't worry. If our CRDI Starex vans start having engine trouble, we'll make it a point to post about it on the Hyundai Starex thread.
For what it's worth, I also have friends who own D4D Innovas, and they haven't had any engine trouble either. I hope Toyota realizes its responsibility to resolve this matter expediently as its reputation will continue to suffer until it does so.
- Jul 2006
- 3,376
August 30th, 2006 08:33 PM #1076guys look at what i found in wikipedia:
Toyota KD engine
From Wikipedia, the free encyclopedia
The Toyota KD engine series is a diesel engine, produced by Toyota, which appeared in 2006.
1KD-FTV
First appeared in the 2000, the 1KD-FTV is one of the newest engines build by Toyota. 1KD-FTV a 3.0L (2982cc) straight-4 common rail variable nozzle coupled with a 32-bit ECU and Multi Pilot Injection System, diesel engine Turbo diesel engine with an Intercooler. It has 16 valves and a DOHC (double overhead camshaft). Bore is 96 mm and stroke is 103 mm. It powers 170 hp(125 kW) at 3400 rpm, and 253 ft·lbf of torque at 1800-3400 rpm. Redline of this engine is at 4200 RPM. Compression ratio is 17.9:1. This engine uses D-4D electronic Common Rail (Common rail direct fuel injection ) technology, produces ultra high pressure, which is about 8 times more than the pressure of the normal fuel injection system. This combined with the 32-bit ECU which controls fuel quantity, valve-timing, and accurate pressure at different engine revolutions result in the most fuel economy and also in the full utilization of power, whether it is during taking off or during taking over, without having to drag the engine revolution to the maximum. Making the achievement with the fuel consumption 11% more effective compared to its predecessor 1KZ-TE engine thus 17% more powerful. Fuel consumption is also 12% more effective than the all new Toyota Hybrid engines. The Pilot Injection System helps smooth engine running like sitting in saloon cars. The noise level is only 49 decibels at the idle speed. The Pilot Injection System produces fuel injection in advance before the main injection starts working, reducing Ignition Lag Time and resulting in continuous and complete combustion. Noise from ignition is also reduced.
This engine was first used in Toyota Land Cruiser Prado and now used in the Toyota Fortuner.
2KD-FTV
The 2KD-FTV is the 2nd generation of the KD engine with a smaller 2.5L (2494 cc) straight-4 common rail variable nozzle turbo coupled with a 32-bit ECU and Multi Pilot Injection System, diesel engine. Like 1KD-FTV, it has 16 valves and is a DOHC engine. Bore is 92 mm and stroke is 93.8 mm. It powers 102 hp (75 kW) at 3600 rpm and 191.7 ft·lbf of torque at 1600-2400 rpm. Redline of this engine is 4400 RPM. This engine also uses D-4D Common Rail (Common rail direct fuel injection ) technology. An intercooler will be introduced next year into this engine.
Used in Toyota Hilux and also Toyota Fortuner and also in Toyota Hiace.
August 30th, 2006 09:51 PM #1077
I agree with Larshell the D4D problem are not unique with 2.5 engines only but also on 3.0 kasi sa aming locality dalawa kami got the same problem, in the previous thread may I quote Numbah5 sabi niya malas lang ako naka problema sa Fortuner 3.0, For me the main problem is the Denso Supply Pump kapag maka problema pa they change the ECU
August 30th, 2006 10:29 PM #1079
Originally Posted by bolantoy
August 30th, 2006 10:31 PM #1080
Getting a toyota would be ideal mostly for those looking for practicality or one who will use it...
China cars
