Results 81 to 90 of 2023
October 27th, 2005 10:14 AM #81
depende na rin kasi cguro sa manufacturers if they really want their engines to be compatible with biodiesel, we cant fault them din. so being informed about biodiesel compatibility is important, baka ung iba kasi di alam gamit nang gamit.
- May 2005
- 341
October 27th, 2005 10:26 AM #82Originally Posted by larshell
October 28th, 2005 11:30 AM #83
This morning i have the symtoms again Hard/Failed starting.I dont know if it is coz of cold weather.But on 2nd try ok na.
Tsikot Member Rank 3
- Sep 2003
- 786
October 28th, 2005 12:41 PM #84My friend's friend was one of the developer of Innova where this guys spent a few months in Japan for this project. I have asked my friend to relay this problem to this guy. Hope to get an answer soon. Will let you know guys.
October 28th, 2005 01:38 PM #85
twas cold last night, pero this morning, wla nman problem sa pag start. thank god
jagxtrm GuestOctober 28th, 2005 03:32 PM #86
guys, my brother gave me his advice... he has a innova d4d G m/t using petron diesel max (without biodiesel or any additives)...
before u stop the engine (by turning off the ignition), u MUST let the engine idle for at least 1 minute (off ang aircon para walang load) para daw mag slow down yng turbine ng turbo...
ang reason daw is to 'release' yng na-build up na pressure sa intake after running the engine at 1,800 rpm or more. also it will prevent early breakdown ng pipes due to 'unreleased' pressure. i think D4D turbo can generate up to 10 to 12 psi of pressure sa intake after running 80 kph or more.
nangyari sa kanya dati na nagmamadali cyang bumaba ng car, at pinatay nya agad yng engine ... pagbalik nya ng car hirap cyang mag start. after 5 mins nag try uli cya mag start & ang result is 1 click start na.
hanggang ngayon wala cyang problem sa hard starting ng innova d4d nya.
please also try this method to ur D4Ds ...
wala naman mawawala sa inyo (except some more fuel consumed) pero for me mas better yng method nya kaysa naman ayaw mag start ng engine & u need to commute dahil ayaw umandar ng ride nyo...
October 28th, 2005 08:45 PM #87
I dont think it has something to do wd Turbo but i will try todo this also.
October 29th, 2005 12:27 PM #88
larshell, hindi kaya sa mga additives na nilagay mo? samin pure diesoline ultra lng tlga gamit namin. wlang kaproblema problema
October 29th, 2005 12:34 PM #89
Originally Posted by wilcats
October 29th, 2005 01:06 PM #90
IMHO...i think the winding down of the turbo doesn't have to do anything with the failed/hard start-up. (Maybe it does, in an indirect way) It looks like its a matter of engine/fuel mismatch. (FYI, the disadvantages of shutting the engine w/out winding the turbo down has been discussed in previous posts)....just my opinion. I also haven't experienced any of these hard start-up. Haven't been using additives/biodiesel, either.
Btw, anybody got the OEM turbo timer already? Kung meron man, saan nabibili ito? Meron na ba sa mga Toyota dealers? Thanks!
No, but it was what sounded closest to Bill, bill. Ha ha ha!
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
