Page 12 of 25 FirstFirst ... 2891011121314151622 ... LastLast
Results 221 to 240 of 500
    Mar 2004
    #221
    Quote Originally Posted by batosai View Post
    Mga expert sa AE101, ask ko lng po anu po ang average fuel consumption nyo sa 4AFE engine, whats your average speed at 2k rpm and 3k rpm.. Is true na ndi na daw pina pa tune up ang 4AFE kasi electronics na. Kaya ko po na tanong ang average speed nyo between this rpm range is parang mabagal na kasi GLI ko. 2k rpm average speed ko is arround 60 kph lng po is it the same as your GLI, and average fuel consumption ko is arround 9-10 Km/L lang. need inputs naman po..
    Thanks and more power po sa ating lahat...
    sir, ang 4AFE na makina is not really a performance engine kaya di dapat asahan ang speed. sa sinasabi mo na 60 kph lang sa 2K rpm, anong gear iyan?
    FC ko sa gli ko model 93, city driving 7 km/liter at highway, 10-11 km/li. Both with A/C in operation. So not so much difference with your FC.
    My car clocked 185 kph with A/C running ( Sa Macapagal hiway, hinabol ko ang BMW )
    #222
    Sir at 5ft gear po un, ndi pa po na overhual engine ko, it has 178,000 on its odometer reading.. Kailangan po ba i pa tune up ang ganitong engine?
    Sep 2009
    #223
    60kph at 5th gear is normal if you shift at very low RPMs (1500 to 2000 RPM), this saves gas and wear and tear on the engine at the cost of speed.
    Mar 2004
    #224
    sir, normally sa pagkatanda ko, 2.5K rpm mapapalo mo na sa 80 KPH ang speed mo sa 5th gear. so, not so much of a difference. pa check mo nalang ang clutch mo sir baka meron ng slippage.
    normal tune up ng makinang ito is just palit spark plug. ay pa check mo na rin pala ang intake throttle mo. baka marumi na. ang sa akin noon, pinalinis ko ke sir speedyfix. odo ng gli ko, 85K ng mabaha-an ni frank.ngayon, di na rin gumagana and the speedometer is about 20kph slower than actual. kaya ang tantiya ko, around 95K lang ang odo ng gli (ni misis pala )
    #225
    Hi to all,
    Nag overheat po corolla ko yesterday (4AFE).. I was travelling along araneta ave yesterday when I notice that my temp gauge are rising, so I decided to pull the car to the near by gas station, the temp reading almost heat the red line but the engine did not die.. I pour water to the radiator to make it cold but the temp reading did not go down, so i decided to turn of the engine to make it cold, after 20 min I decided to open the rediator cup start the engine again and add water, the temp start to rise agian so I decided to call a mechanic, finally the culprit was a busted thermostat, luckily celica ( toyota parts supllier) was near by for the parts. After installing the new thermostat it all work well again, my question is what are the thing should I check that might be damage due to this overheating,
    Tnx
    Mar 2004
    #226
    Hi to all,
    Tnx
    sir, nangyari din sa oto ko iyan noon. the culprit was the radiator fan. talagang namatay ang makina ko. but after cooling it down, then replacing the fan, it started ok. la naman damage.
    ang sa case mo, its just mild case compared to my expreience. however, just to make sure, try to do the following.
    buksan mo ang radiator cap. have someone crank the engine. obserbahan mo kung me tumatalsik na cooling water coming from the opening of the radiator. if so, nadale ang cylinder head gasket ng makina. kung wala, no need to worry about. most damage occuring after an overheated engine ay ang cylinder head gasket, except kung patay talaga ang makina, then buhusan ng malamig na tubig ang radiator (dahil wala na cooling water), may delikado na mag crack ang engine block. kaya, di ina-advise na buhusan agad ng tubig ang radiator (fill it up) pag nag overheat ang makina. palamigin muna bago lagyan ulit ng tubig ang radiator.
    #227
    baguhan po.....
    i would like to know po what are the best/ideal brands/specs po para sa mga sumusunod.....
    BATTERY
    SPARK PLUG
    ENGINE OIL
    GEAR OIL
    OIL FILTER
    OIL SEAL
    BELTS (a/c, alternator, timing)
    BREAK PADS
    SHOCKS
    hindi lang po para sa akin ito, para na rin po sa ibang mga nagmamay-ari ng TOYOTA COROLLAs specially yung 10year old pataas.....
    i'm planning for a little tuning-up sa COROLLA ko.....
    THANXZS PO.....
  8. #228
    '92 4AFE ko (A/T) has 191k kms on the odo. 6kms/liter consumption ko, purely city driving. Medyo malakas na manginig yung engine, and not as responsive as it used to be. Feeling ko kailangan na ng top overhaul... Any reliable but affordable places for overhaul?
    #229
    Quote Originally Posted by beryltherese View Post
    baguhan po.....
    BATTERY
    SPARK PLUG
    ENGINE OIL
    GEAR OIL
    OIL FILTER
    OIL SEAL
    BREAK PADS
    SHOCKS
    THANXZS PO.....
    up ko lang po.....
    Mar 2004
    #230
    baguhan po.....
    BATTERY
    SPARK PLUG
    ENGINE OIL
    GEAR OIL
    OIL FILTER
    OIL SEAL
    BREAK PADS
    SHOCKS
    THANXZS PO.....
    battery: motolite na green, maintenance free
    spark plug: denso
    engine oil: hi-grade oil ng petron (dyan lang naman kasi ako nagpapa change oil ). would have tried using other brands but so far, 10 years na sa akin ang gli, ok naman ang takbo using ordinary oil. yun nga lang, dapat ang change oil sked dapat masunod.
    gear oil: yung sa petron na rin. pina-pa check ko gear oil tuwing mag pa change oil ako
    oil filter: any brand
    oil seal: so far di pa ako naka pag palit ng oil seal
    belts: what is available sa auto supply. meron ako listahan dati ng mga belt sizes ng gli sa glove compartment pero nasira ng mabaha ni bagyo frank
    brake pads: just bought one from auto supply. dala ko lang sample kasi marami pala klase iyan. so far, ok naman. just changed mine last summer.
    shocks: di pa ako naka palit. pero parang kelangan na kasi iba na ang tunog tuwing malulubak.
    And most important of all: Folks, dapat lagi nyo check ang rubber boots sa CV drive. pag me punit iyan, papasukin ng buhangin, todas ang bearings nyo.
    Fuel: lagi karga ko is petron XCS (utang kasi )
    So far, ang tune up ko is just palit spark plugs. have done intake throttle cleaning way back 5 years before. till now, ok pa rin. ang aircon lang sa akin ang lagi nagluluko. pero ng mapaayos ko last december, till now ok pa rin.
    hope this helps
    #231
    maraming salamat po sir, talagang nag-aabang ako ng post, sa saturday na kasi ang skedyul ko para dito......
    gusto ko ako bumili ng mga kakailanganin para makatawad o bawas sa gastos.....
    THANXZS AGAIN SIR.....
  12. #232
    Quote Originally Posted by paolorenzo View Post
    Up po. Any recommended shops specializing in 4AFE? Pasig area sana. Yung meron diagnostic tool (OBD2 ba ang AE101 4AFE?) would be ideal...
    Mahina na hatak ng GLi ko eh...
    Dec 2009
    #233
    ganyan din dati gli ko, taga pasig din ako, 7km/Li lang ang consumption... pinalitan ko ng spark plug at air filter, i bought them at toyota C5, ako lang nag nagkabit, ang laki ng ginanda ng takbo, at ngayon 8km/Li na ang consumption.
    #234
    mga sir may problema ako sa powersteering ko may leak then pinagawa ko sabi oil seal so ginagawa nila. tinanggal ung buong powersteering assembly then pinalitan ng oilseal.. pag kagawa ginamit ko roadtest after mga 5 hrs may pumutok nakita sa ilalim so i check it nakita ko nag leak na ung ATF ko asar talaga so batch job. sabi nila ung oilseal na nabili mahinang klase. so sila na bumili ng oilseal so ginawa nila ulit. ayos ang gawa may leak parin.. nung check ko may lumabas na hangin sa assembly. asar na asar ako sabi nila may sira na daw ung assembly so need ko daw bumili ng surplus.. mga worth 7k. badtrip tlg tingin ko di sila marunong. baka may alam kayo near in cainta na marunong gumawa. thanks
    May 2008
    #235
    Nung magleak ang power steering ng gli 95 ko nung 2001, dinala ko sa banawe. The repair was made where I bought the repair kit. so walang kawala kung may diprensya. As I remember, 3 months warranty yata. Ok pa naman until now. I dont remember the shop but my message is have it repaired where you buy the kit.
    Mar 2004
    #236
    Quote Originally Posted by Ejboy View Post
    Have been trying to find kung sa-an na lumipat ang dating Lawton auto supply sa Paco.Meron kasi silang mga stand by mechanics doon, magagaling na rin, kayang-kaya pantayan ang trabaho ng casa.Doon ko pina-ayos ang leak sa PS ko, palit timing belt, brake pads at inayos din ang nag leak na oil seal sa distributor. Sir, bakit di mo try sa banawe, yung auto supply na meron silang mga mekaniko?
    #237
    newbie lang po ako! pero naexperience ko na din po yung leak ng power steering ng Bigbody ko.... napansin ko kasi na bumaba na yung level ng ATF reservoir halos nsa minimum na after ko gamitin ng whole day check ko uli kinabukasan bumaba na uli cya, so nagdecide ako na ipacheck sa mekaniko d2 sa fairview, upon checking nakita nya nga na basa yung tinatapatan ng power steering assembly so advice nya sa akin na palitan oilseal, nagawa naman nya ng maayos until now ok naman na yung power steering ng auto ko....
    Sep 2010
    #238
    magkano na po ang shock absorber (front, left & right) complete set ngayon? ayos din po ba ang surplus? thanks
    Aug 2010
    #239
    read mode and watch moe...
    Jun 2006
    #240
    Quote Originally Posted by MusclePower22 View Post
    san sa fairview yan paps? may leak na rin kasi PS ng AE101 ko e. thanks!
Toyota Corolla AE101 Owners & Discussions [Merged]
