Page 13 of 50 FirstFirst ... 39101112131415161723 ... LastLast
Results 121 to 130 of 500
    #121
    Tama price pag wala nang papagawang major.
    Sep 2002
    #122
    depending on the condition, the price could be ok.
    fyi, may binenta friend ko 95 gli for 175k last month.
    #123
    Quote Originally Posted by denox
    mga tol, tulong naman. im planning to buy a '94 corolla gli, all power, 15" mags, sound set up, lowered, 2nd owned. ok na ba sa 175thou? need your opinions mga tol. thanks in advance.
    the only dis advantage is that because its orange your car (If you acquire it) will easily get spotted when you do your motel activity.
    Goodluck.
    Try to push for the stereo
    The set up isnt really expensive. without the stereo am guessing that its set up cost only 4 to 6 thousand
    Apr 2005
    #124
    ok na yan. medyo mura pa nga dahil gli yan. check if everything works dahil all power yan, minsan meron kang di napapansin na hindi pala gumagana.
    Sep 2005
    #125
    175K tapos hanapan mo ng sira like power windows, door locks, oil leaks, filters, rust, tires, missing screws or bolts, etc. Sum it all up then ask for a discount on all the repairs to be done
    Sep 2005
    #126
    don't forget to check the papers if it's really authentic.. that's the most important one
    Feb 2006
    #127
    murang mura na yan!
    Apr 2006
    #128
    i've had this problem for the last six months, during this time, i;ve changed the master clutch assy twice,(the last just the other day, but after one day of use, the fluid has become dirty again)... the master clutch repair kit twice (the last one in Feb 06), and the secondary clutch repair kit once... i suddenly 'lost' the clutch Tuesday last week before replacing the master clutch assy (it worked fine from the replacement of the repair kit in Feb, though the fluid was already dirty a day after it had been changed)... before this(after intitally replacing the master assy in Nov 05), i had experienced the clutch pedal dropping & dropping until i had to nurse it to my suki mechaniko... they said after the Feb 06 work that maybe it's the secondary assy that's causing the master assy to fail... ANY COMMENTS OUT THERE ON MY PROBLEM??? I dont want to have the same experience again (LOSING THE CLUTCH WHILE DRIVING, WITH NO WARNING)... THANKS
    #129
    hi everybody..
    mewbie here...
    just want want to ask you guys the pros and cons (then solution to cons)
    of having a Corolla XL model 97 (came from cas jan. '98)
    please help me with this. i want your answers. thanks in advance
    Last edited by GlennSter; May 11th, 2006 at 01:19 PM. Reason: please avoid vague thread titles.thanks!!!
    Jul 2006
    #130
    Quote Originally Posted by ghosthunter
    4AGE-20v silver top = 135 to 150 HP
    4AGE-20v black top = 150 to 165 HP
    (depending the engine you got)
    sir, just wondering how come the black top and the silver top have two different horse power output when they are both 4age-20v.
    by the way, what do XL, XE, GL, GLi and GLXI mean?
Toyota Corolla AE101 Owners & Discussions [Merged]
