Page 93 of 179 FirstFirst ... 4383899091929394959697103143 ... LastLast
Results 1,841 to 1,860 of 3575
    Dec 2004
    #1841
    Quote Originally Posted by kafph2000 View Post
    Si Jason yung SA ko. Okay naman ako sa Toyota Pasig kasi malaki parking space nila at madali puntahan for me. But of course, just like you, same typical casa experiences for me ("normal lang yan", "palitin na to", etc..) =))
    Okay, I haven't checked the manual for that. Will do it later. Thanks!
    wala na si jason sa toyota pasig, lumipat na ng company. try niyo si celso antonio, bago lang pero maasikaso. kaka-pms ko lang last tuesday
    May 2005
    #1842
    ^Ano pangalan? We have a suking SA at Toyota Pasig also. They're also the only dealer so far that allows me to bring my own motor oil. I'm not all satisfied with their service though. Ilang beses na they keep telling us to change parts that are still good (imagine recommending i change my 15,000kms old brake pads).
    Re. specific works being done at a certain mileage interval (Every 5K, 10K, 20K, 40K), you can find it on the owner's manual.. Usual heavy service stops are the 20K and 40K.
    Toyota Otis allows customers to bring in their own oil and oil filter and maybe even other parts. I just had PMS yesterday at Otis for an out-of-warranty-vehicle using my own supplies. BTW, no extra charges for bringing in your own supplies.
    Of course for vehicles still covered by the warranty, should use the supplies from the dealer to prevent voiding the vehicle's warranty from Toyota.
    #1843
    Can anyone confirm the battery I need? My car is a 1.6 G M/T. I wanna replace my battery bec it's more than 3 years already. Stock battery pa.
    Sent from my GT-N7100 using Tapatalk 4 Beta
    The Motorola website suggests N40. Motolite | Order A Battery
    Feb 2009
    #1844
    i have the NS60 installed on my Altis. Same size with the stock battery; fits in the battery holder and bracket.
    #1845
    I really don't understand the codes in Batteries
    Then there's the 1SN. My service advisor said the battery for my Altis is a 1SN so that's N40 for or NS60?
    Jul 2010
    #1846
    Check this www.motolite.com
    Your altis batt is N40
    For FAQs go to www.motolite.com/faq.ph to check all your queries regarding batteries everthings there. Goodluck!
    #1847
    All corollas/Altis pala have the same type of battery lang
    Jul 2010
    #1848
    Check also www.motolite.com/faq.php this is for FAQ all infos are here cath
    Jul 2010
    #1849
    If i were you get infos there then get amaron Ü
    Dec 2004
    #1850
    1SN and NS40 are different terms based on naming standards (American / European / Japanese). Meron pa yang complications with fit, design, polarity, etc. para na lang hindi kayo malito, when you need a battery, say the exact model, trim, and year of your unit. The stores and manufacturers would already know which specific battery one you need, may database naman yan
    #1851
    The Vios uses the same battery too.
    #1852
    pati innova gas sir
    #1853
    If that's the case better get the NS60 instead. A little bigger but with better reserve capacity
    Jul 2010
    #1854
    Quote Originally Posted by Nell View Post
    Just hoping it will fit in the battery tray of the oem's Ü
    #1855
    Quote Originally Posted by joemelr View Post
    If the tray is the same size as the vios, yes it fits.
    Feb 2009
    #1856
    it fits! i have it on my altis.
    Jan 2009
    #1857
    Stop contemplating. Go for the Toyo DRBs na... higher thread wear rating versus the RE002s.
    These were the DRBs from the Vios after 45-50K kms.
    finally bought tires... ended up with the SP Sport 01... 6.6K / piece... quite expensive but happy with the choice, can't compromise safety since its already the rainy season. Noticed that the SP Sport 01 tires when already near the end of its service life tends to become a bit noisy. It lasted 51TKM but you can push the tire life up to 55-60TKM .
    I just bought 3 and used my unused spare... planning to run the unsused spare for another 30TKM since its already near the end of it's shelf life. Ill buy 2 tires and have the newer one as spare.
    #1858
    Quote Originally Posted by kinse View Post
    Ampch... after all the drama you kept to the OEM ones. :D
    #1859
    Just had my 20,000kms service at Toyota Shaw. Total damage was P 2,917. I brought my own oil and my engine air filter was not replaced (As i use a K&N washable filter). Had the cabin air filter replaced though and it cost me P 906.
    Dec 2004
    #1860
    kung puwede to sa toyota shaw, then i guess puwede rin dapat sa pasig. how many liters of oil did you use? also, how's the k&n filter? is it worth it in the long run and how much / where can you get this? thanks
Toyota Corolla 10th Generation Altis Owners [continued]
