Page 187 of 358 FirstFirst ... 87137177183184185186187188189190191197237287 ... LastLast
Results 1,861 to 1,870 of 3575
    #1861
    Yes, pwede sa Toyota Pasig as well (i had my 15K service done at Pasig). They even asked me if i brought my own oil filter (i left my Baldwin filter at home... doh). The 1.6L Altis ZR engine uses around 4.2L to 4.3L of oil; i usually buy 2 gallons + 1 litre to cover two oil changes (tell the dealer to return the unused oil so you can use it on your next service and save a little).
    You can order the K&N locally from shops such as Speedlab but it's cheaper to buy from the US. I bought mine online and had a relative hand carry it home; it cost me USD36 on Amazon last year. Part number is 33-2360. For me in the long run it is worth it (the drop-in filter) as i just have to clean this maybe once a year or so and there's no need to replace your filter after that. I noticed also i have better high rpm performance with the K&N filter on (i guess the engine is less strained to breathe at high rpm as against the conventional air filter).
    #1862
    Just had my 20,000kms service at Toyota Shaw. Total damage was P 2,917. I brought my own oil and my engine air filter was not replaced (As i use a K&N washable filter). Had the cabin air filter replaced though and it cost me P 906.
    vinj, anong oil na gamit mo for your 10th gen?
    #1863
    Yung pinapakyaw mo. Zic A 10W-40
    #1864
    Cheaper ba if I bring my own oil?
    Sent from my GT-N7100 using Tapatalk 4 Beta
    #1865
    reasonably priced kasi e. kaya kahit every 5k km OCI ok lang. kaso wala na daw stock sa ngayon.
    yes cheaper cause for the same price, you can buy better oil.
    #1866
    OT: SIr CB, san kayo kumukuha ng ZIC? kay Jard din? Thanks!
    #1867
    Huwaaat!!! Pati ZIC nagkakaubusan? Kay Jard out of stock?
    If you know where and what oil to buy, yes. For the semi-synth oil i bring, it's cheaper and better than the regular mineral oil of the CASA.
    Nov 2011
    #1868
    Hi guys, meron bang naka nitrogen tires sa inyo? If meron, pa share naman ng experiences, pros and cons. thanks in advance
    #1869
    Quote Originally Posted by kiamoyman View Post
    Dati (when i changed rims/tyres, the nitro was free).
    Pros: Matagal magbawas and pressure remain more consistent at running temperature.
    Cons: You have to pay for a refill in most cases and you can't just put nitro anywhere; in my case, my refills were all using gas station pahangin; not much of a problem given my tyre never got a flat that time so pressure in all tyres always remained consistent.
    Feb 2011
    #1870
    share ko lang experience ko kanina.
    nagpa-carwash ako kaninang hapon, dumating ako dito sa bahay magdi-dilim na. nung pumasok ako sa garahe, biglang nabuhay yung headlight ng altis. umatras ulit ako. tapus pinasok ko ulit sa garahe, nabuhay ulit.
    siguro napihit nung carwash boy yung switch para sa headlight.
    accidentally, meron palang auto-switch on ang headlight ng altis. ngayon ko lang na-discover.hahaha
    BTW, ang model ng altis ko ay 2010 1.6V pre-facelifted.
    ang tanong ko lang po, ok lang ba na laging iwan sa auto ang headlights naten?
    TIA.
Toyota Corolla 10th Generation Altis Owners [continued]
