Page 411 of 749 FirstFirst ... 311361401407408409410411412413414415421461511 ... LastLast
Results 8,201 to 8,220 of 14970
    Oct 2007
    #8201
    [SIZE=4]Congratz Pres/Mod MELEDSON!!!!![/SIZE]
    Pag president ka ata ng isang car club e qualified ka maging moderator.
    Aug 2005
    #8202
    Quote Originally Posted by shadow3616931 View Post
    Thanks.
    I think nagkataon lang.
    May 2007
    #8203
    Quote Originally Posted by qtshecu View Post
    just a quick question, suppose ung gear natin nasa 5th or 4th gear, when decreasing the speed, do u normally shift down one gear at a time? or let's say, from 4th gear, derecho 2nd gear?
    what's the best practice? kc ako i usually shift down one gear at a (5th to 4th, 4th to 3rd, 3rd to 2nd).
    *qtshecu,
    Here's my practice:
    1. Shifting up- 1st, 2nd, 3rd, 4th, 5th (In order)
    2. Shifting down- Depende. Usually, from current gear, Neutral ako palagi (No intention to overtake or Not sure kung ano next move ko). Then, depende sa speed and RPM (this will take cross-checking or feeling), I shift to the desired gear (Nasa manual naman). Say, from 5th gear-Neutral-then desired gear.
    I found the practice helpful sa mga sudden stop or intention to stop. Brake na lang ang tinatapakan ko. Hindi ako namamatayan ng makina. I saw this practice among jeepney/taxi drivers many years back. For me, It really helps.
    Aug 2005
    #8204
    May nabasa ako dati na di daw safe na iwan ang car sa neutal while moving, you will never know if you will need engine braking or sudden acceleration daw kasi. Kung gradual ang pag slow down ko, I downshift sequencially. So para if I need power, gas na lang ang tatapakan. Nasa right gear na ako. Nag skip lang ako ng gear/s pag sudden decceleration.
    Driving Tip. Ang stock na brakes ay humihina pag mainit na. Use engine brake to support the brakes to prevent over heat ng brakes. Iyon mga bababa ng bundok tulad ng baguio, take note.
    Driving tip: In a 2-lane road, when overtaking, do not upshift in the middle of the overtaking maneuver. Up shift only when you are safely in front of the overtaken vehicle. Why? Delikado na mabitin kung nagkamali ka sa pag shift - di pumasok.
    Comments to these tips are welcomed/encouraged.
    Dec 2007
    #8205
    aba moderator na pala si president!! congrats!! ala bang blowout dyan sa EB??
    I "second the mention." :naughty2: hehehe... Congrats, Pres. MelEdson!
    #8206
    Bro Meledson congrats for being the moderator. Goodluck!!
    #8207
    Quote Originally Posted by Marfin View Post
    Eto nga pala picture yung scuffplate na outher cover, eto po ba sir yung sinasabinyo?
    at yung chrome wiper cover nakakabit sa vanzy ko.
    Bro Marfin ang sinasabi ko ung sa door sa likod i think ung scuffplate para sa mga side doors. Tama ba?
    Aug 2005
    #8208
    Quote Originally Posted by woohoo View Post
    Quote Originally Posted by lenuj View Post
    Thanks. Kailangan tuloy na behaved ako dito
    Sorry, walang blow out.
    Dec 2007
    #8209
    May nabasa ako dati na di daw safe na iwan ang car sa neutral while moving, you will never know if you will need engine braking or sudden acceleration daw kasi. Kung gradual ang pag slow down ko, I downshift sequencially. So para if I need power, gas na lang ang tatapakan. Nasa right gear na ako. Nag skip lang ako ng gear/s pag sudden deceleration.
    I agree somewhat. Kapag M/T ang gamit kong sasakyan, madalas akong mag-neutral para makatipid sa fuel, but at the same time, naka-ready ako na mag-kambyo ulit kung saan at kailan nararapat (either downshift for engine braking or upshift for sudden acceleration, depende sa flow ng traffic at dami ng kasabayang sasakyan). Baka dala na rin ng pagka-Kapampangan ko ito, tantiya-tantiya (lalo na/kahit sa pagluluto)...
    Sa A/T din, madalas akong mag-neutral, lalo na't malapit nang tumigil (traffic, humps, atbp.)... Bakit? Kasi, mas malakas ang preno dahil hindi pinipilit ng makina na isulong pa rin ang sasakyan. Kapag malapit nang tumama sa humps, ibinabalik ko na sa "D" para fluid ang motion.
    Sep 2005
    #8210
    pag A/T pano ang engine break? nararamdaman ko yan minsan pag downhill.. tapos ni release ko yung gas without stepping on the break.. parang nag slow down sya with engine breaking..
    Aug 2005
    #8211
    Use 2, 1 or L.
    Di ko alam ang format ng A/T ng Avanza.
    Sa 1.6 Altis A/T, I can turn off the O/D para kung nasa 4'th gear, bumaba ng 3rd. Sa Shift lever, available ang 2 at L.
    #8212
    I don't own an Avanza, I do have a Civic and Accord A/T but I am sure it also applies.... Use the lower gears like D3, 2, and L. The lower the gear used the stronger the engine breaking so if you want maximum engine breaking use L. Use this for steep downhills pero be warned it also consumes more gas than the standard D gear so use it only when needed..... Hope that helps....
    Dec 2007
    #8213
    Eto nga pala picture yung scuffplate na outer cover, eto po ba sir yung sinasabinyo?
    Sir Marfin, kung 600 yung pair/set ng scuffplate outer cover at kung matutuloy ako sa EB (dahil may magpaparaya sa beige pullhandles), ako na ang bibili niyang outer covers na yan.
    Thanks for being so helpful sa mga nagpapabili...
    Oct 2007
    #8214
    Naku di na tayo puede mag post ng kalokohan sisitahin tayo ni Pres/Mod Meledson
    Jan 2008
    #8215
    CONGRATS PRES MELEDSON.....Moderator ka na pala......
    for marfin: bro reserve mo na rin sakin chrome wiper ha... thanks
    Dec 2007
    #8216
    Oops... pang Avanza J pala yung scuffplate outer covers... sorry... di pala bagay sa G ko.. hehe... sorry.
    #8217
    Kagabi, di lang ako ang nadagdag na moderator dito sa tsikot. :D
    wahawwwwwwwww!!!!!!!!! congrat prezzzzzzz!!!!BLOWOUT!!!
    Nov 2007
    #8218
    +1 blow out pres
    spongee...san mo ulit nabili yung door trims (tama ba?) ano name nung shop sa may ligaya. camvass ako kung san mura ipagawa yung bumper ko
    TIA
    Mar 2004
    #8219
    Additonal lang sa DT 2:
    It is my practice lalo na sa 2 lane road lang, for safety purposes, when the overtaking car comes abreast of me, I slow down a bit to give the overtaking car plenty of room to maneuver. Kasi, kung di ko bibigyan ng room, tapos bigla lang me kasalubong, ang tendency ng overtaking car is to swerve unto your lane, which may cause unwanted accidents.
    Aug 2005
    #8220
    Quote Originally Posted by burjegol View Post
    That is what you call defensive driving.
