mga Sirs, gamit ko po ay fx 5K gas 1994 model, gusto kong palitan ng auxilliary fan ang cooling fan ng radiator instead na originally ay fan sha na makina ang nagda drive thru fan belt. dahil po sa mkakabawas sa load ng makina ay malamang makatipid din sa fuel consumption. meron na po kayang gumawa ng ganitong set up?
at xensha na po kung na post na itong question ko previously, TIA sa mga mag rereply...peace...
The mechanic even surrendered and sent me back the van (after a total of 4 days check-up and testing). I decided then to bring it to another recommended shop, which by the way, looks a lot more lousy as their shop is not that organized and a bit "makalat"
I'm running out of options, that is why I said to myself, sige na nga, no choice at tumirik na. Luckily, this guy checked first the used carburetor repair kit and said that a new gasket was not installed, he opened the carburetor again and installed the gasket. The problem still occurs. He then compression checked all the cylinders and found that the cylinder 1 (valves) was loose already. To cut the story short again, my van was recommended for a top overhaul, but after removing the cylinder head, he showed me that the cylinders was a bit loose, though it is still useable, he might not guarantee its lifespan, that is why I decided to have the general overhaul. I picked-up the van just this morning and hoping that all is well already. For now, its break-in period, and I have to be gentle
with one relay and few feet of wiring. And you are right, need to check first the alternator if it can handle the additional load of electric radiator fan.
