Page 50 of 161 FirstFirst ... 4046474849505152535460100150 ... LastLast
Results 491 to 500 of 1604
    Jan 2009
    #491
    Quote Originally Posted by arieslhon View Post
    size ng wiper is 16" or 400mm po...
    sir pwd ba banana blade wiper sa fx?
    madali lang ba siya ikabit?kasi diba may screw ung wiper nang fx?
    Aug 2008
    #492
    Quote Originally Posted by sherlabs03 View Post
    Guys,
    Ang FX GL97 7k dual aircon, dalawa ba expansion valve o isa lang?
    Thanks.
    Dalawa, isa sa harap, isa sa likod.
    Aug 2006
    #493
    pag napalit ka ng wiper to banana type magpapalit ka din ng wiper arm kasi nga screw type ang FX....
    Feb 2009
    #494
    for those who pm me
    as requested, thats my old model fx. you can copy if you want to specially the engine set-up.
    Feb 2009
    #495
    Feb 2009
    #496
    Feb 2009
    #497
    Feb 2009
    #498
    Aug 2006
    #499
    sir nice set up!!!
    sir ask ko lang spec ng mags nyo? ganda kasi how much po bili nyo? tnks
    Feb 2009
    #500
    my mags size is 14 inches. gulong nya is 195/70/14. medyo malaki sa stock diameter ng gulong ng fx. pero naka turbo kasi ako kaya kayang kaya nya. kung ordinary lang engine mo. mas maganda 185/65/14 yong gulong mo para pareho pa rin diameter. sa stock na gulong which is 175R13. pwede rin 185/70/14. pwede rin 195/60/15 or 195/55/15 kung gusto mo 15 inches mags.
    quick reply doon sa previous inqueries:
    1. amoy gasolina sa mga carburated na gas engines (5k and 7K) - you need to change your carburator or you can let it be overhauled kung wala kayo budget for a replacement. be sure though na bili kayo overhauling gasket para palitan lahat gaskets sa loob ng carburador. as in total baklas sa loob ang mangyayari kaya dapat magaling na mekaniko mag overhaul sa carburator nyo.
    2. overheating - unahin nyo muna i check yong radiator. much better pa general overhaul nyo (around 400 to 500 pesos lang naman labor). pag overheat pa rin, thats the time you open the cylinder head to check kung worn-out na head gasket. at the same time, you can already check the cylinder liner and piston ring kung may damage since bukas na rin yong makina.
Tamaraw FX Owners
