Page 149 of 163 FirstFirst ... 4999139145146147148149150151152153159 ... LastLast
Results 1,481 to 1,490 of 1628
    Feb 2013
    #1481
    Baka yunh filter sa fuel tank.
    Dec 2007
    #1482
    Quote Originally Posted by siopaonatoasted View Post
    My understanding from the postings re tank filter is that it's mesh type screen and that it only needs to be cleaned.
    Jun 2013
    #1483
    afaik, 2009 up wala ng choking problem sa d4-d.
    nice to hear that
    thanks
    Oct 2011
    #1484
    kung 2006 pa ang Fortuner, prolly ung shorter SCV pa yan that is the culprit of the d4-d choking issue.
    #1485
    Saan phoenix ? Sa cabantuan , malapit sa may Gt--oil ?
    Sent from my GT-I9300 using Tapatalk 4 Beta
    phoenix gas station at north edsa po. yung tapat ng sm annex yata yun going cubao. dati dun din ako nagpapa gas for my lancer ala naman problema. pero once lang ako nagpa karga ng diesel for our innova, nagkaron na ng choking and worst tumirik na. pagbaba ng tangke, medyo madumi ang diesel. di ko alam kung na-timing lang sa phoenix pero nung shell naman ang knakarga namin wala naman choking or stalling. 80k pa lang po ang tinakbo ng innova, 2nd owner na po ako. yung gas filter na pinalitan, mukha syang gas filter ng car pero mas maliit. di ko alam kung san nakakabit. kelangan daw palitan yun kasi nagloloss pressure. didn't botheR to inquire further kasi nagmamadali na kami umuwi kasi late na namin kinuha yung innova from cabanatuan. basta mahalaga ok na sya. yung testing ng fuel injector medyo mahal sa kanila. 800 per nozzle plus 1500 labor. sa motor doctor sa antipolo 2,100 lang.
    Oct 2011
    #1486
    mabuti at naayos na din innova mo sir. monitor mo na lang baka bumalik ulit problema.
    Dec 2007
    #1487
    Quote Originally Posted by roger_jonv View Post
    yung gas filter na pinalitan, mukha syang gas filter ng car pero mas maliit. di ko alam kung san nakakabit. kelangan daw palitan yun kasi nagloloss pressure..
    You are probably referring to the fuel filter ELEMENT. Yes, pinapalitan ito regularly. Ito dapat muna ang pinapalitan kapag may fuel related issues. In any case, you are better off with a new SCV on your fuel injection pump and a cleaned fuel tank.
    Oct 2011
    #1488
    so it's fuel filter element pala and not gas filter. naliton ako dun.
    #1489
    Quote Originally Posted by timo07 View Post
    its not the fuel filter element kasi kapapalit ko lang ng new original filter element last month. umilaw kasi yung signal ng fuel filter sa dashboard kaya pinalitan na last may. the filter im refering to is kamukha sya ng fuel filter ng gasoline car pag nagpatune up ako.. yung may kabitan ng hose.. anyway, ok naman na takbo and so far i'm monitoring for signs of potential back-job. one year warranty naman ang supply pump with new and longer scv.
    Jul 2011
    #1490
    Gas filter? Where is this located?
    i think it is located beside the throttle body, a small white gas filter connected to a vacuum hose.
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
