Page 146 of 265 FirstFirst ... 4696136142143144145146147148149150156196246 ... LastLast
Results 2,901 to 2,920 of 5286
    Apr 2004
    #2901
    Mega-sirs, I just ordered a Fortuner 4x2 V. Any suggestions on where to mount my phone? On my 2014 Fort, I use a Scosche magicmount placed beside the AC controls. I can't seem to find a similar blank space on the dash of the new model. Big deal for me since I'm a heavy user of Waze.
    Quote Originally Posted by zix888 View Post
    Transplant done. Dyno tomorrow
    bro, yun maliit na vgt kaya ang naka install sa 2.8 innova kaya medyo mababa output?
    #2903
    Quote Originally Posted by dragonmate View Post
    I put my mount on the dash, then landscape orientation while using Waze. It falls below the 4 inch limit.
    Sent from my SM-G930F using Tsikot Forums mobile app
    #2904
    Dito lang tayo sir sa segment na ito, done w/ monty (215whp) and fort (180), moving on w/ the next experimental unit.
    May MuX ka na pala, bro?
    Kulang na lang yung Trailblazer.
    #2905
    Yan din ang gusto ko silipin, not sure if detuned lang siya or pang 2.4 yung turbo
    #2906
    Quote Originally Posted by zoomzoom View Post
    And Everest, Papi
    Adjusting light sensitivity for V variants. Tested and verified From FCP*FB
    For V variant owners of the new Fort with dark tint on the windshield that find it annoying that your headlights turn on every time you pass under a lot of trees or if the skies are overcast, you can adjust the sensitivity of the headlight by doing the following which I saw in another group.
    覧覧覧覧覧覧覧覧覧覧
    You can adjust auto headlight sensitivity through the software that controls it
    1) Switch ignition to ON
    2) Make sure dimmer switch is in lowbeam and not pushed forward into constant high beam
    3) Turn light switch onto park light setting
    4) Turn ignition OFF
    5) Hold headlights into highbeam
    6) While highbeam is pulled on (pulled and not pushed to constant highbeam), turn to headlight then back to park light (not auto) 5 times. You will need 2 hands to do this.
    7) Release high beam (the headlamps will flash in relation to what setting they are currently set on. It should flash 3 times with the setting being 0 which is the default. (if they don't flash you are not in the settings)
    8) Hold highbeam on again and turn between headlight and park light setting.
    The number of times you turn it will vary the sensitivity.
    Once -40
    Twice -20
    Three 0
    Four +20
    Five +40
    9) Once you have turned between headlamps and park light for your desired preference, release the highbeam.
    The headlamps will flash for the number that you have selected.
    And once it flashes say once, you are all complete.
    Good luck!
    pinaka mahirap intindihin na topic sa thai forums ahhaha
    #2909
    [QUOTE=zix888;2853433]
    Quote Originally Posted by chenneth View Post
    Ilan kg po ba yung stock 17?
    Stock 17 wheel/tire weighs 29kgs.
    6kgs lighter than the 18 wheel/tire combo.
    So 24 Kg ang nadagdag sa akin sir. Kaya pala parang may nag-iba. Hmm thanks po Sir
    Sent from my ASUS_Z012D using Tsikot Forums mobile app
    #2910
    Uy beri nice! 👌
    #2911
    *ssaloon
    sir san po kayo nag pagawa ng leatherette seats nyo?
    how much ang inabot?
    Aug 2009
    #2912
    [QUOTE=chenneth;2853698]
    Should be around 30kg heavier because of the spare
    #2913
    [QUOTE=mikhael;2853735]
    G mags pa din spare ko po hehe
    ah so youll confirm sooner or later. thanks. 👍
    #2915
    Quote Originally Posted by DevAaron View Post
    *ssaloon
    Seatmate in Mandaluyong, 9.5k for all 3 rows.
    #2916
    Quote Originally Posted by ssaloon View Post
    thanks.. malayo lang sakin mandaluyong.. baka dito ko ipagawa sa branch nila sa Pranaque.
    sana pareho sila ng gawa ng main branch nila.
    Apr 2017
    #2917
    Matanong n lng po, may reverse cam n po b fort G at?
    Sent from my E6853 using Tsikot Forums mobile app
    Quote Originally Posted by wilson3 View Post
    Wala... Kahit back up sensor wala.
    Aug 2012
    #2919
    Hinubaran na nila G variant ngayon
    Sent from my GT-I9500 using Tapatalk
    Apr 2017
    #2920
    Tnx
2016 Toyota Fortuner
