Page 148 of 156 FirstFirst ... 4898138144145146147148149150151152 ... LastLast
Results 2,941 to 2,960 of 5286
    Jun 2018
    Quote Originally Posted by Shutterbug View Post
    Do we still need to cut out a portion of the tint even if non-metallic naman naka install?
    Instruction from the LTO on how to apply the sticker:
    "Make sure that the space of application behind the rear view mirror is clean, dry and has no window film / tint applied."
    No distinction between metallic / non-metallic.
    Oct 2007
    As what sir heavenlee said, dapat walang tint when you stick the sticker.
    Hay salamat, after 2 year of owning my fortuner, nakuha ko rin plate number ko.
    *vinrem, sir when you got the new plate number, meron bang kasamang bolts to screw in? Nakuha ko na rin just two days ago pero walang mga bolts. Dati kasi sa Innova ko when the new plates were distributed merong kasamang mga bolts.....
    Oct 2007
    Quote Originally Posted by attyallanlatras View Post
    Sir, wala pong kasamang bolts and screws, also, nagkataon na PMS ko nung time na yun, pinakabit ko na lang agad sa Toyota.
    Dec 2009
    hi sirs,good day.
    i am looking to replace my old 06 fortuner with the new one, but only the G model as the prices are so steep now a days, would like to ask what is the maximum discount for 40% DP and 4 yrs to pay scheme.
    please advise.
    Mga bossing, would it be possible to install a tire pressure monitoring system sa Forty natin? If so, how much kaya?
    Sir yung bolt na ginamit ng casa is just yung ordinary bolt? hindi ba sya madaling tangalin sa mga may malilikot na kamay?...hehehe I just want some security thats all...
    Jun 2018
    Use uncommon bolts? Like allen capscrew bolts, perhaps?
    i would be concerned with the quality of the turnilyos.
    they must be strong enough to do the job, lest the steering system split open on the road.
    Oct 2007
    Hahaha sorry sir, di ko napansin, check ko pag uwi ko ng pinas next week, may nakita akong acrylic plate protector, I might get one para di masira ang plaka and sabay na change ng bolts if ever ordinary lang.
    Sep 2012
    OEM cruise control install and activation for fortuner G Gen2 2016 to 2019 Manual and Automatic Transmission. Pm me if interested. TIA
    just a question. the new fortuner doesnt uave an L gear. Is the s1 the replacement to use instead of the L?
    Wow...that much for a liter bottle of oil, filter & injector cleaning fuel additive????
    Nothing would likely be claimed under warranty between now & May....but, if peace of mind is what you're after, follow the good doc's advice.
    Apr 2009
    Me too, since I grew up in a car shop, all my cars when its time for their PMS, I tell the SA to just change the oil and oil filter. No other fancy stuff (eng detailing, injector cleaner, and other unnecessary ek ek). I see the faces of SA not liking me probably because they won't have add'l kita.
    Quote Originally Posted by LN106G View Post
    I'd advise ŕ la carte over buffet when it comes to dealership menus, too. Post warranty? DIY, if one can. Home cooking isn't only budget friendly, it's almost always the healthier diet.[emoji4]
    Jan 2008
    For 3,400 pesos.. i was able to do change oil for my fortuner! Not a top-up ha... DIY nga lang..
    Used an original toyota oil 5w-30 for 1,500 pesos per 4 liter can that says "made in japan" plus an original toyota oil filter.
    [emoji106][emoji106][emoji106]
    this would have been better..with free air and ac filter cleaning and stronger oil.
    guys just a question. new fortuner owner here. how do i open the coolant cap? was checking and it wont rotate because it has some sort of “lock” to prevent rotation. i didnt want to just pop it off and couldnt find instructions in the manual... any video showing me how to do this will do fine also
    Quote Originally Posted by troydl View Post
    same with my 2005 innova.
    i didn't bother with it anymore.
    i just look at the overflow cannister, and fillit to the mark from time to time. like, five or so times in a dozen years. heh heh.
    i hasn't given me problems.
2016 Toyota Fortuner
