Results 551 to 560 of 691
- Jan 2010
- 8
October 5th, 2011 10:14 PM #551thanks sir impulzz. damn. mahal pala ng lspv. sana hindi aabot ng 6k, preno pa naman. pwede kayang remedyohan na lang?
October 5th, 2011 10:49 PM #552
kung yung o-ring lang ang nasira baka pwede. yung sa akin kasi siguro sinubukan pa repair nung previous owner, the mechanic chipped off a big part sa may lip so ang nangyayari pag lumusong ako sa baha, pinapasok ng tubig, contaminates the fluid and internal brake parts.
- Jan 2010
- 8
October 8th, 2011 06:32 PM #553i tried removing yung LSPV kanina, grabe yung kalawang.... naghanap ako ng piyesa dito sa baguio- wala. pero nag order ako sa isang auto supply shop kaso by monday pa malalaman kung meron stock yung supplier nila, pag wala pa rin i will be ordering directly from manila ... my last resort will be converting my rear brake line to toyota- mas marami daw kasi piyesa...
ask ko ulet, ano yung pagkaiba ng VITARA JLX sa JXL ?
October 9th, 2011 10:26 AM #554
jlx trim lang lumabas dito sa atin. baka binaligtad lang yung emblem nya hehehee
- Jul 2010
- 109
October 10th, 2011 03:02 AM #555Hi guys,
I'm suspecting that I got bad wheel bearings. Are these readily replaceable or is it like most Vitara parts that I need to order somewhere?
- Jan 2010
- 8
- Sep 2011
- 14
October 13th, 2011 10:48 AM #557mga vitara masters, ask ko lang ung vitara ko kapag start ang engine mataas ang minor bumababa lang kapag binukas ko na aircon? at how many liters of oil ang para sa 1.6L engine? nagpa-change oil kasi ako ung 4 liters ay halos 3/4 lng ng stick.
October 13th, 2011 08:50 PM #558
on cold start my idle is at 1200 to 1300 rpm then when the engine warms up it goes down to 700rpm
as for oil the manual says when you change the oil filter you put in 4.2 liters of oil
- Sep 2011
- 14
October 14th, 2011 10:00 AM #559sir bakit kaya kapag ginagamit ko na cya with aircon normal naman rpm nya. pero kapag ini-off ko n aircon, tumataas rpm nya. ano kaya problem? hindi naman nagpa-fluctuate rpm.
- Sep 2011
- 14
October 14th, 2011 10:06 AM #560hindi lng basta tumaas kundi halos nsa 2000 rpm at medyo umiingay makina?
Camry will be easier to maintain since FWD and comes with an NA engine. The Legacy GT is AWD and...
Why are Mazda 6s (especially new ones) so rare on...
