Results 571 to 580 of 691
- Sep 2011
- 14
February 21st, 2012 10:04 AM #571d' best talaga vitara sa long drive at akyatan. I travelled from quezon city to Bolinao, Pangasinan with my vitara walang pahingahan antindi ng hatak at bilis. apat pa sa center seat at isa sa tabi ko passenger! hindi na rin mabigat consumption dahil nasa 11-12 km/l. After Bolinao, we tavelled to Baler, Aurora dun ko nakita tindi ng vitara, walang problema sa akyatan...
- May 2011
- 7
March 6th, 2012 03:51 PM #573Good day po sa inyo mga sir, just want to share a problem on my vitara (escudo converted) Automatic Transmission
Last time ng post n ko dito, and some of the problems eh na fix na somehow. Pero i am still not satisfied with the result.
I just observed the following
1. Kapag ng hard break po ako, then mag proceed n with driving, hindi kaagad siya kakagat. I expect kasi na once i release the break dpat aandar. Ang nangyayari po kasi, hindi siya agad aandar then, bigla ng lng syang aandar n may kasamang malakas n forward movement. As if parang nabanga yung likod ko. Pakiramdam ko nanikit yung break then if its time to release na parang naiipit tuloy siya.
2. Kapag mainit ang panahon at nkabukas ang aircon, and i was in traffic. My squeaking sound po ako naririning. Mas madalas po ito lumbas kpag nag steer n g wheel habang stationary
Any input regarding po dito will be greatly appreciated. Thanks!
- Jan 2008
- 4,363
March 6th, 2012 04:49 PM #574check mo yung transmission cable connected sa accelerator.. baka need ng adjustment.. sa squeaking naman check mo yung crankshaft pulley baka need na replacement
- May 2011
- 7
March 6th, 2012 04:53 PM #575Hi Sir, thanks sa reply. sa tantya nu po nsa magkano pa ung range ng magagastos if ever?
March 7th, 2012 10:04 AM #576
Bro most probably:
On #1 Check your clearance on the brakes baka masyado malapit. Also check mo din hydraulic piston ng brake sa harap at likod kung nag stuck up.
On #2 baka kailangan mo na magpalit ng belt o kaya maghigpit ng belt o check mo din sa tensioner ng belt baka bearing may problema. Also check the fluid.
I think it may not cost a thousand pesos kung yan lang problema.
- May 2011
- 7
March 7th, 2012 10:54 AM #577thanks thanks mga sir.
kagagaling ko lng kay sir Rod ng filmars. ung belt lng daw maluwag. so hinigpitan nya. sana mging ok na. mmya ko p lng atually ma test eh. Yung sa break, sabi nya sa transmission daw un. Kaso di daw nya forte ang automatic transmission eh. Chineck nya ung ATF ko parang kulang daw, so dingdagan nya. Ill test later kung mangyayari p yung problem nananinikit na break.
- Sep 2011
- 14
March 7th, 2012 04:20 PM #578manual tranny gamit ko. kahit pang-porma s city maganda talaga vitara, hindi nalalaos porma!
- Jan 2010
- 8
March 11th, 2012 10:29 AM #580+1 papost naman pics ng vitara nyo.
- im a vitara owner from baguio city. i've swapped my 96 honda vtec for this powerful beast, no regrets 101% satisfied owner.i even towed my cousins land cruiser using my vit hehehe malakas talaga sa akyatan kahit naka normal driving ka lang. cheers!
ganito dapat magbenta ng new Ranger :grin:
2022 Ford Ranger (next gen rumors)
