Results 561 to 570 of 691
October 14th, 2011 04:49 PM #561
baka there is something wrong with either MAF sensor or idle position sensor... i experienced it once sa vit dirty MAF. idle was always at 900 to 1000. so asked my friend to check error code and viola MAF sensor error... so he just cleaned and ayos na swerte.
October 15th, 2011 09:48 AM #562
Maayos kausap si Jonathan sa Olympia. Pati yung mechanic dun sa Mang Lodie kabisado na Vitara.
- Sep 2011
- 14
- Jan 2010
- 8
November 5th, 2011 09:57 AM #564may problema nanaman ako sa vitara ko, nung nakuha ko kasi yung vitara, napansin ko na walang air filter na nakalagay sa air filter box, nung nilagyan ko ng filter at hinigpitan ko yung bolts and clamps, at pagstart ko e puti na yung lumalabas na usok sa tail pipe kahit na matagal na naka idle ganun parin, hindi rin stable yung idle nya. help naman mga sir .salamat.
November 5th, 2011 05:09 PM #566
- Jan 2010
- 8
November 5th, 2011 06:54 PM #567thanks sir impulz, sana nga maayos at minimal lang ang gastos. i'll keep you posted. thanks
- Jul 2010
- 109
November 14th, 2011 11:50 PM #568Hi guys,
http://multiply.com/mu/kenngarcia/im...nmid=498875254
I hope you can help me find replacement parts for my Vit. I need a couple of inner door handles/levers like the ones in the pictures.
If by any chance you know of some surplus shops in Evangelista, that would be great.
TIA!
/Kenn
- Jul 2010
- 109
November 16th, 2011 01:47 PM #569
- Jun 2008
- 1,740
November 16th, 2011 03:03 PM #570Una sa lahat: Wala akong Vitara.
Pag walang air filter ok pero pag meyron maputi usok at unstable idle. Maybe fuel air ratio ay hindi tama kasi was adjusted na walang air filter dapat readjust ayon sa standard. Baka mataas ang flow restriction ng air filter kaya kapos ang hangin na pumapasok. Try drop in filter like K&N baka sakali.
Na oversize na ba ang cylinder bore? My experience on my old carburated toyota corona many years ago: Namuti ang usok at kapos sa hatak kapag my air filter after the bore was oversized. Ang solution ko: I used filter mat (commonly use in aircon) as air filter. Problem was solved. HTH
hindi ko na nalaman boss kung same amount. 2nd and 4th yr(dec29) nagpalit ng cvt fluid 3,300 ung sa...
All New 2016 Civic
