Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 53
    Sep 2019
    Hi guys, just want to ask any recommended shop in Metro Manila to install lower control arm bushing?
    I'm planning to buy OE control arm bushing then ipapa-install nalang since may crack na yung bushing ng sasakyan.
    Yun ibang nakita ko kasi buong lower control arm assembly yung binebenta abutin ako 18k pesos if assembly masakit sa bulsa.
    Thanks
    Most suspension shops will have a bushing service kit. Some bigger shops have a press'. Search near your area baka meron. You can use fb search. Suspension shop marikina for example.
    Any shop with a hydraulic press should be able to install suspension bushings.
    caveat.
    replacement of the bushings alone, and not the entire assembly, might result in a "not-too-satisfactory" performance.
    but as it's the much cheaper solution... i'd try it, myself.
    Basta meron press. Sobrang bilis lang nyan palitan.
    May 2016
    Quote Originally Posted by tensazangetsu View Post
    Thanks
    Curious lang, ano unit mo?
    Sep 2019
    caveat.
    Thanks doc! I'm planning to replace it with the original bushing. Will buy the bushing from Casa then have it installed outside.
    Or would it be better if ipagawa ko na sa casa yung pag install ng bushing?
    Sep 2019
    Thanks sir! :D
    Quote Originally Posted by Lakwatsero View Post
    3rd gen Mazda 3 skyactiv sir
    Jun 2005
    I honestly doubt may bushing sa casa. Assemblies sila normally
    Sent from my MI MAX 2 using Tapatalk
Best shop in Metro Manila to install lower control arm bushing?
