Page 1 of 3 123 LastLast
Results 1 to 20 of 57
    Sep 2019
    Hi guys, just want to ask any recommended shop in Metro Manila to install lower control arm bushing?
    I'm planning to buy OE control arm bushing then ipapa-install nalang since may crack na yung bushing ng sasakyan.
    Yun ibang nakita ko kasi buong lower control arm assembly yung binebenta abutin ako 18k pesos if assembly masakit sa bulsa.
    Thanks
    Most suspension shops will have a bushing service kit. Some bigger shops have a press'. Search near your area baka meron. You can use fb search. Suspension shop marikina for example.
    Any shop with a hydraulic press should be able to install suspension bushings.
    caveat.
    replacement of the bushings alone, and not the entire assembly, might result in a "not-too-satisfactory" performance.
    but as it's the much cheaper solution... i'd try it, myself.
    Basta meron press. Sobrang bilis lang nyan palitan.
    May 2016
    Quote Originally Posted by tensazangetsu View Post
    Thanks
    Curious lang, ano unit mo?
    Sep 2019
    caveat.
    Thanks doc! I'm planning to replace it with the original bushing. Will buy the bushing from Casa then have it installed outside.
    Or would it be better if ipagawa ko na sa casa yung pag install ng bushing?
    Sep 2019
    Thanks sir! :D
    Quote Originally Posted by Lakwatsero View Post
    3rd gen Mazda 3 skyactiv sir
    Jun 2005
    I honestly doubt may bushing sa casa. Assemblies sila normally
    Sent from my MI MAX 2 using Tapatalk
    Sep 2019
    Quote Originally Posted by sirkosero View Post
    I already called casa already sir kahapon meron daw sila for 1.2k+ per piece. I also thought na assembly lang kasi yung niquote nila sa akin last year yung buong assembly then last week found out na meron pala yung bushing lang mismo.
    Genuine? Can you share the part numbers, sir? The factory parts catalogue I've seen has those integral w/ the arms. Thanks!
    Sep 2019
    Eto sir TK48-34-470A
    Lower Control Arm Front Bushing - Mazda (TK48-34-47A) | TascaParts.com
    Awesome! Thanks, sir![emoji120] Not grabbin' bush #4? Best done together.
    Sep 2019
    Anytime sir!
    Aug 2005
    Thanks sir! :D
    Sir ano problem ng car mo? Maingay ba pag nalulubak?
    Same din sa akin and recommended ng casa change the assembly which cost 18k.
    Thanks po
    Excellent job finding the bushings and the price is great compared to my hyundais bushings lol.
    Quote Originally Posted by bhybhoy View Post
    Thanks po
    Bushings are wear and tear items. The lower arm ones normally fail on front wheel drive vehicles.
    Sep 2019
    I'll check with Casa on Monday sir if they have bush #4. I tried checking ang nakita ko lang is the replacement part.
    Not sure actually if #3 or #4 yung may crack na bushing sa akin. I thought isa lang yung bushing nya. Thanks for the suggestion sir!
    BUSH, SUSPENSION JIKIU BH25166 KD35-34-46A, B6S-34-3B_BH, KD35-34-3H_BH
    Sep 2019
    Yes sir maingay pag nalubak. Casa told me na may crack yung bushing few months ago.
Best shop in Metro Manila to install lower control arm bushing?
