Results 1 to 10 of 53
- Sep 2019
- 107
January 3rd, 2020 07:22 PM #1Hi guys, just want to ask any recommended shop in Metro Manila to install lower control arm bushing?
I'm planning to buy OE control arm bushing then ipapa-install nalang since may crack na yung bushing ng sasakyan.
Yun ibang nakita ko kasi buong lower control arm assembly yung binebenta abutin ako 18k pesos if assembly masakit sa bulsa.
Thanks
January 3rd, 2020 07:46 PM #2
Most suspension shops will have a bushing service kit. Some bigger shops have a press'. Search near your area baka meron. You can use fb search. Suspension shop marikina for example.
January 4th, 2020 10:11 AM #3
Any shop with a hydraulic press should be able to install suspension bushings.
- 52,910
January 4th, 2020 10:25 AM #4caveat.
replacement of the bushings alone, and not the entire assembly, might result in a "not-too-satisfactory" performance.
but as it's the much cheaper solution... i'd try it, myself.
January 4th, 2020 11:16 AM #6
Basta meron press. Sobrang bilis lang nyan palitan.
- May 2016
- 546
- Sep 2019
- 107
January 4th, 2020 10:03 PM #8
- Sep 2019
- 107
January 4th, 2020 10:05 PM #9
- Jun 2005
- 3,774
January 4th, 2020 11:11 PM #10
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
