Page 69 of 76 FirstFirst ... 1959656667686970717273 ... LastLast
Results 1,361 to 1,380 of 1510
    Oct 2015
    #1361
    Afaik most mainstream brands already have China based manufacturing. At least for commercial tires. Even premium brands like Michelin and Pirelli have China made tires. The brands will insist that quality is the same while keeping cost down. In my experience, the good brands made in China are decent, but country of origin still correlates to quality. In buying tires I would choose brand first, then country of origin.
    May 2011
    #1362
    What is best tire kaya ford fiesta 185/55/15 with budget of 3500 per tire? Yung goodyear ko nadudulasan ako. Palit ako dalawa
    #1363
    Quote Originally Posted by 3GEMS View Post
    Try going 195/55R15.
    Toyo DRBs are good and budget friendly.
    Sep 2016
    #1364
    how much per tire sir? i bought my tires for 3.3k per tire.
    #1365
    The DRB is a pretty popular tire and it's a decent tire. My only gripe is that it's directional so you can't rotate front left to rear right and so on, unlike asymmetric tires.
    #1366
    Went all out with the replacement tires for my Mazda 3:
    So far though, since I haven't brought the car out of town, I can hardly feel any difference between the Potenzas and the China tires that came with the car when I bought it. At the end of the day, the car's inherent handling characteristics matter more than the tires.
    I also plan to compare the long-term durability of the Potenzas vs the Ecstas I have on my other car.
    I dont like them 2154517 the side walls are somewhat soft. Good thing yours are xl. I think the sidewalls are abit reinforced. How wide are your rims?
    #1368
    Sidewall stiffness is dependent on the tire model, not the size. 215/45R17 is the most common size for 17" tires (my 10th gen Altis also uses the same tires).
    My stock rims are 7 inches wide so ideal width is 205 or 215.
    Mar 2015
    #1369
    walang pang 2 years ganito na nangyari, 4 tires. lagi naman chine-check yun air pressure, 30-31psi
    Jul 2016
    #1370
    Yung triangle tire china subok ko na sa trucking business. Naka ilang set nako. Ok parin sya kahit semi kalbo na. Makunat din sya mataas thread wear.
    Sent from my SM-J500G using Tsikot Forums mobile app
    Quote Originally Posted by ads13 View Post
    Ilang km tinakbo? 30k?
    Mar 2015
    #1372
    18-19k km lang ang tinakbo
    Sep 2016
    #1373
    yung GT Radial Maxmiller pro 3,680 per piece na. noon e 3.3k lang.ahahah.I haven't tried other brands yet eh. Can you suggest brands that have durable tires.
    Feb 2017
    #1374
    mga sirs.. planning to buy cheap tires. ano mas maganda? Sailun TerraMax A/T 235/75R15 or Delium TERRA CRUISER IA-205 235/75R15. thank you!
    #1375
    AFAIK mababa na yang 30-31 PSI
    #1376
    Depends on the car. Mine recommends 32F/30R. Most sedans fall under that range, while SUVs are around 35-38 PSI.
    A difference of 1-2 PSI should not negatively impact a tire's longevity.
    Jul 2013
    #1377
    Google led me to bad reviews about this tire. Probably not suited for tropical climate.
    Feb 2005
    #1378
    Quote Originally Posted by huntsman View Post
    How long did you use your 3.3k tire? It's normal that prices will go up after a few years
    I also use GT Maxmiler and it lasted 2.5 years and run around 50k kms before i changed it with another set of the same brand and specs.
    If it serves you well and you had good experience with it, doesn't make sense to look for other brand/s.
    DriveFast.DieHappy.
    #1379
    DriveFast.DieHappy.
    A couple of good friends of mine are tire importers bro. There will be a major price increase this year due to high raw material costs and Php USD rate. When the increase will be will depend on inventory levels of each brand. But definitely cost will be up significantly, it is only a question of when.
    Feb 2017
    #1380
The Best Brand of Tires
