Page 67 of 76 FirstFirst ... 1757636465666768697071 ... LastLast
Results 1,321 to 1,340 of 1510
    Jun 2006
    #1321
    Ganun ba sa lahat ng store na napuntahan mo? You can try other brands like Continental, Michelin or GT.
    Dec 2009
    #1322
    Quote Originally Posted by Horsepower View Post
    Isa lang plan ko bilin dahil nagka problema yung isa kong gulong pag ibang brand kasi maiiba yung thread. Napansin ko lang dun sa dunlop pinaka mura na yung 3.6k dahil sa iba kong na canvas nasa 4k-4.5k. Samantalang bili ko sa Goodyear sa Adventure namin 3.5k lang.
    Sent from my H220 using Tapatalk
    #1323
    Quote Originally Posted by mp88 View Post
    Guys any feedback on Dunlop LM703 and Kumho KU39 tires? Thanks!
    I have KU39 on my Altis now, had LM703 on our Altis before.
    The KU39 (Ecsta LE Sport) is a premium high performance tire so it's naturally grippier than the LM703 which is just a touring tire. Pretty quiet tire too, the KU39.
    The LM703 is being phased out now, and its successor is the LM704. Even between the LM704 and KU39, I'd still pick the KU39.
    Quote Originally Posted by radz15 View Post
    Mga tol ask ko lang. Ginto ba talaga presyo ng dunlop tires? Haha mas mahal pa kasi yung Dunlop EC300 165/65r14 ng Celerio ko kesa sa Goodyear Duraplus assurance 185/80r14 ng Adventure.
    No. You should try calling different tire shops and checking out different brands. Both the EC300 and Assurance Duraplus are entry-level eco tires from Dunlop and Goodyear, respectively. They take long to wear out, but aren't very grippy. That's okay for drivers who don't drive fast.
    Try to check if the Duraplus comes in the size for your Celerio. Other brands you might want to check are the Yokohama BluEarth, Bridgestone Ecopia, and Michelin Energy XM2.
    If you want to go for midrange brands, you have the Kumho Solus, Falken Sincera, and Toyo NanoEnergy.
    Budget brands are also available such as the GT Champiro Eco, Achilles 2233, and Accelera Phi.
    I would stay away from Chinese brands. You can go cheap when it comes to toys for your car, but not your tires.
    Continentals and Michelins are expensive. The MaxContact 5 and Pilot Sport 3 that I checked out are 1.6x more expensive than the Kumho Ecsta that I bought.
    The only affordable Michelin is the Energy XM2 but it has really poor reviews because while it's a long-wearing eco-tire, it has poor grip whether wet or dry.
    GTs are affordable, especially the Champiro Eco. You can take it a step higher and get the high-performance HPY if it comes in your size.
    Dec 2009
    #1324
    Thanks sir jut. Ok lang ba na 3 tires dunlop ec300 at yung isa ibang brand?. Hindi ba malaking effect kung ibang thread pattern yung isang gulong?..
    #1325
    Nope. At the very least, have the same kind of tires for the same axle. You can have two pairs of different brands for the front and rear. Not ideal, but definitely better than 3 identical tires and one tire that's different.
    I had that setup before. Kumho Ecsta SPT in front, Dunlop LM703 in the rear. Ever since though, I made it a point to replace my tires all at the same time. I rotate my tires every 10,000 km to ensure even wear.
    Bakit 3 tires lang papalitan mo? Either go 2 or 4 tires.
    Dec 2009
    #1326
    Ohh i see. I mean isa lang papalitan ko. Ok yung 3 stock dunlop tires ko. Yung isa lang yung nagka problema. Nag check ako ng price ng ec300 165/65r14. Pinaka mura kong na canvas 3.6k kadalasan 4k-4.5k and i find it ridiculous. Dahil 3.5k lang bili ko sa Goodyear assurance 185/80r14 sa isa naming sasakyan.
    #1327
    How many km have the other 3 tires travelled?
    I would still stick with replacing one EC300 rather than a pair of 2 cheaper tires if the other 3 tires aren't that worn out anyway.
    Dec 2009
    #1328
    30k pa lang. Makapal pa sya. Kung hindi ok na may nag iisang gulong na naiiba siguro patusin ko na yung 3.6k na ec300.
    Ano kaya ang effect pag may isang ibang tread pattern sa gulong?. Thanks!
    #1329
    30k is already at least half of your tires' treadlife. Most eco tires wear out at around 40-60k km.
    Even if you just change one tire, the wear will not be even because the other tire on the same axle is much more worn compared to the new tire.
    It's better to just change two tires, then put them in the rear, then wear out the older front tires and replace them too eventually.
    Is your spare tire the same size as the other 4 or is it a donut? If it's not a donut, you can turn your 30k km tire into a spare, put the fresh spare on one wheel, and the new tire on the other wheel of the same axle. That way, you have a fresh pair of tires on one axle.
    Having tires of different tread patterns/brands on the same axle is like wearing a Nike shoe on one foot and an Adidas on the other. Tires are designed to work as a pair - for example, if one tire has better water dispersion properties than the other, you can lose control during heavy rains as one tire will lose traction.
    Yes, messing up tires is pricey because you always have to replace in pairs. You can always go the cheap route and just change one tire, but remember, tires are the only thing between the road and your car so it's best to err on the side of caution.
    Dec 2009
    #1330
    Donut yung spare tire eh. Thanks sir jut!
    Dec 2009
    #1331
    Guys any recommend tire shop?. Naghahanap kasi ako ng ec300 165/65r14. Wala kasi sa mga shop na Jiga, Gomags, Minerva at S&R. Sa tireshakk lang meron tas 4k pa ang price
    Dec 2009
    #1332
    Guys ano ba mas practical. Isa gulong lang kasi need ko palitan. Mas ok bang bumili ako ng isang gulong na same dun sa tatlo (P4,000)ec300 or bumili ng dalawang gulong na ibang brand (P2,000 each) GT radial eco
    Jan 2016
    #1333
    kung ako yan paps, 1 tire lang, cheapest but reliable brand, dapat lang pareho ng size, malayo pang palitan ang 3 tires mo, normally pag 50k kms ako magpalit, pero niro rotate ko para pantay ang upod. If u decide na 1 lang bihin, piliin mo yung location ng pinakapudpod mo na gulong at dun mo ilagay para maghabulan sila ng pudpod.
    Dec 2009
    #1334
    Yan sana plano ko kaso may negative effect daw pag maiba yung tread pattern kahit same size
    Dec 2009
    #1335
    Good day sir jut. Galing ako sa tireshakk Magallanes para bumili na ng new ec300 pero they manage na mahanap yung singaw. Hopefully maging ok na.
    Nakausap ko yung taga tireshakk tinanong ko kung bakit sobrang mahal ng ec300 compared sa mga competitors na nasa 2.5k+ lang. Ang sabi nya ec300 daw yung high-end tire para sa mga small cars kaya mahal. Yung mura daw na dunlop for 165 65r14 is yung sp touring.
    #1336
    They were able to fix your tire? That's great! Much cheaper than getting a new pair of tires.
    The SP is Dunlop's touring tire - better comfort and grip compared to the EC. Just because Dunlop sells them more expensively doesn't mean it's more high-end. [emoji6]
    So how much is the SP in your size?
    Dec 2009
    #1337
    Yes sir nahanap nila yung singaw. But still under observation.
    Yung SP nila is 3.5k. 500 cheaper compared sa ec300.
    Sep 2016
    #1338
    ung tires ko sa likod e 185R14 ung isa.ung isa naman e 195. wala pa kasi akong pangbili ng isa pang tire eh.hahaha.
    Nov 2016
    #1339
    Super happy with my Thunderer tires - 205/65R15 for my Innova. Just needed basic tires for city driving and compared to my old ones na Goodyear (mahal), and recent ones na West Lake (pumutok agad and matagtag), ito sobrang kapit kahit basa and favorite ko sobrang tahimik kahit mabilis na ako!
    Recommending this also to my aunt who needs new tires and everyone else. Super nice find! Got them at 02-291-6517 sa Servitek Valenzuela. They also deliver daw (which I will do next time) and they also have auto shops in Cavite, Pasig, Cubao daw.
    Jan 2010
    #1340
    guys, what would you recommend as replacement for 195/55/15 tires? na-try ko yung chipipay na sailun before kaya lang palaging lumalambot. weekly ko lang ginagamit ang altis, from antipolo to qc. hope may ma-recommend din kayong mabibilhan within the eastern zone
The Best Brand of Tires
