Page 137 of 151 FirstFirst ... 3787127133134135136137138139140141147 ... LastLast
Results 1,361 to 1,370 of 1510
    Oct 2015
    #1361
    Afaik most mainstream brands already have China based manufacturing. At least for commercial tires. Even premium brands like Michelin and Pirelli have China made tires. The brands will insist that quality is the same while keeping cost down. In my experience, the good brands made in China are decent, but country of origin still correlates to quality. In buying tires I would choose brand first, then country of origin.
    May 2011
    #1362
    What is best tire kaya ford fiesta 185/55/15 with budget of 3500 per tire? Yung goodyear ko nadudulasan ako. Palit ako dalawa
    #1363
    Quote Originally Posted by 3GEMS View Post
    Try going 195/55R15.
    Toyo DRBs are good and budget friendly.
    Sep 2016
    #1364
    how much per tire sir? i bought my tires for 3.3k per tire.
    #1365
    The DRB is a pretty popular tire and it's a decent tire. My only gripe is that it's directional so you can't rotate front left to rear right and so on, unlike asymmetric tires.
    #1366
    Went all out with the replacement tires for my Mazda 3:
    So far though, since I haven't brought the car out of town, I can hardly feel any difference between the Potenzas and the China tires that came with the car when I bought it. At the end of the day, the car's inherent handling characteristics matter more than the tires.
    I also plan to compare the long-term durability of the Potenzas vs the Ecstas I have on my other car.
    #1367
    I dont like them 2154517 the side walls are somewhat soft. Good thing yours are xl. I think the sidewalls are abit reinforced. How wide are your rims?
    #1368
    Sidewall stiffness is dependent on the tire model, not the size. 215/45R17 is the most common size for 17" tires (my 10th gen Altis also uses the same tires).
    My stock rims are 7 inches wide so ideal width is 205 or 215.
    Mar 2015
    #1369
    walang pang 2 years ganito na nangyari, 4 tires. lagi naman chine-check yun air pressure, 30-31psi
    Jul 2016
    #1370
    Yung triangle tire china subok ko na sa trucking business. Naka ilang set nako. Ok parin sya kahit semi kalbo na. Makunat din sya mataas thread wear.
    Sent from my SM-J500G using Tsikot Forums mobile app
The Best Brand of Tires
