Results 491 to 500 of 1510
- Jan 2009
- 38
April 10th, 2010 12:48 PM #491makisingit na rin po ako. tanong ko po kung magkano normally ang yokohama 185/65r14? need to buy two for my nissan exalta. sumabog yung isa kong gulong at lumabas yung wire. salamat po.
April 13th, 2010 04:08 PM #492
Planning to buy Michelin 235/70 r15 for crosswind...
Ano ang pinaka latest na year manufactured ang gulong na ito? mostly nakita ko 2007... may update ba kayo? thanxs a lot!
April 13th, 2010 10:07 PM #493
April 14th, 2010 12:27 PM #494
sir newbie is here...
tanong ko lang sir bakit yung sa advie ko na pirelli chrono ay 195R14C lng tapos yung sa iba my "/" sign sya? tulad ng 185/65R14C...
ano b pagkaiba nito sir?
April 14th, 2010 12:31 PM #495
Both are truck tires or light-duty commercial tires - denoted by the C at the end. Usually vans have this equipped. I remember our old Kia Pregio had 195R14C tires too.
The second tire spec (185/65R14C) is more conventional because car tires use almost the same system.
"185" is the tread width in millimeters. The "65" is the aspect ratio - the height of the sidewall as a percentage of the tread width. In this case, the sidewall height is 65% of 185mm - do the math.
I have no idea why some tires have the aspect ratio removed from their specs.
April 14th, 2010 03:59 PM #496
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 14th, 2010 04:09 PM #497
- May 2009
- 119
April 20th, 2010 02:02 PM #498anyone knows kung magkano sa blumentritt, banawe or evang ang yoko A drive 205/65/r15 pudpod na kasi yun s306 ko sa rear so 2 pcs ang need ko dito kasi sa batangas area ang range is the cheapest is 3.4K/pc at highest is 3.6k...painform naman po kung may recent lang bumili para pagluwas ko sa manila pwede ko sadyain kung significant yung difference..thanks
April 22nd, 2010 09:08 PM #499
April 25th, 2010 01:33 PM #500
Traffic!
