Results 231 to 240 of 5235
August 6th, 2006 07:59 PM #231
ganon ba.... kc meron kinabit malapit sa foglamp, eh mahina pakinggan.. 1 set lng nilgay ng owner, i told him dapat 2 sets, ayaw naman.. parang kuripot kc yun.. hehehehe....
August 7th, 2006 08:01 AM #232
I think VIC aftermarket parts are good ones. Ingat lang sa mga peke nyan. To look for the ginuine VIC for oil filters, look for the JAPANESE CODE and PROD CODE (combination of numbers and letters) on the top side of the filter. Using a fake one can seriously damage your engine because of its ineffeciency..
August 7th, 2006 08:18 AM #233
HORN kong ginamit is STEBEL NAUTILUS. Parang sa mga bus ang tunog nya. Except buong-buo ang tunog. Kinabit ko sa bandang braces ng bumber ko. Ok naman ang location kasi hindi siya nababasa ng tubig and putik. I don't need to splice the original wirings altough i also changed the recommended relay (30 A). Also, I used the recommended wire thickness (AWG) so that voltage loss would be very minimal. All I did was re-route the wirings (without splicing any wire) from the relay/fuse box compartment into the outside. So that anytime puede kong ibalik sa stock ung busina ko without hassle within less than 1 minutes.. :transform
August 7th, 2006 05:53 PM #234
Hey guys, you want to set an EB for DMAX owners? Tamang tama baka pwede na rin itapat eng EB ng Isuzu Group! (IMG)
- Aug 2006
- 147
August 7th, 2006 09:19 PM #235isuzu has launched the new dmax LS. same features as the old LS. nice new colors blood red and grey.
August 7th, 2006 11:04 PM #236
pare tinangal mo ba yun bumper mo yun nilagay mo yun nautilus? Nilagay ko yun stebel magnum sa place ng stock horns. No modifications needed.
August 8th, 2006 05:00 AM #237
Originally Posted by x_jason_x
August 8th, 2006 04:56 PM #239
hello, regarding sa horn, magandi rin kung isasabay mo ang hella supertone and the stebel nautilus.. yung nautilus ko nasa likod ng front bumber and the supertone nasa harap lang, behind the front grill...
August 9th, 2006 12:18 PM #240
Ung sa akin nilagay ko sa bandang likod ng foglight. No need to remove the bumber and the grill. All I did was removed first the mud guard near the fender (above the front tire) and you could see the metal braces of the bumper. I just drilled a hole on that braceand install my NAUTILUS HORN. I didn't need to splice any wire. I just re-routed the relay wirings from the inside of the relay panel to the outside. (ayaw ko kasing galawin ang stock wiring ko)
presently using one for all our vehicles (including bikes). OK naman. pansin ko lang na umiinit...
Need recommendations on tire inflator.
