Results 31 to 40 of 215
October 12th, 2017 07:19 PM #31
The issues listed are by uber/grab owners. imagine mo naman 18-24hours per day. bugbog... Even the Vios na gamit as uber/grab for sure madami din issues.
Sent from my SM-G935F using Tsikot Forums mobile appLast edited by StockEngine; October 12th, 2017 at 07:22 PM.
October 12th, 2017 09:45 PM #32
Vios taxis are notorious for cooling problems. Third gen not as bad, but I have experienced bad heat soak in AT-equipped units.
First batch had the bad batch of flywheels that did not mesh properly with the starters.
Possible most of the other issues were also more common to early units.
AC is still weak on new units. Still rattles sometimes on start up.
- Jun 2015
- 2,751
October 12th, 2017 11:12 PM #33- The G4 usually develops a huge gap between the hood and front bumper over time. Just look at G4s on the road. The old hatchback doesn't have that issue. Not sure if the latest hatchbacks will have the same problem now that it has a bumper design similar to the G4.
- For manual transmission, I usually read about snapping clutch cables.
- The engine seems quite picky with fuel. Mine needs at least 95 RON. Otherwise, I get a noisy engine with audible knocks.
Sent from my ASUS_T00J using Tapatalk
October 12th, 2017 11:17 PM #34
Yes it was faulty
Replaced at no cost due to warranty
Sent from my GT-P3110 using Tsikot Forums mobile app
- Mar 2008
- 54,246
October 12th, 2017 11:52 PM #35
- Jun 2015
- 2,751
October 13th, 2017 10:37 PM #37Oh, I thought it was because the bumper is too nose heavy and made with something flimsy.
I've read that some owners "fix" it by loosening the bolts of the hood and pulling it forward enough to close the gap. Not sure if that'll cause another set of problems but that's one way to do it.
- Jun 2008
- 1,741
October 15th, 2017 10:02 AM #38Meron na lancer sa panahon ng mirage. Mirage ang kalaban ng Toyota starlet. Lancer ang katapat ng ford escort & Toyota corolla.
Sent from my NX549J using Tsikot Forums mobile appLast edited by weisshorn; October 15th, 2017 at 10:07 AM.
- Nov 2017
- 1
November 16th, 2017 12:03 PM #39
- Mar 2008
- 54,246
November 18th, 2017 12:55 AM #40
Coolant...
