Page 5 of 11 FirstFirst 123456789 ... LastLast
Results 81 to 100 of 215
    Quote Originally Posted by chronicle View Post
    Check you tail pipe. Might be the screw is loose.
    baka nga yun hanger rubber. lumutong agad?
    Apr 2014
    #82
    most likely yung tail pipe garnish lang na descrew.
    madami din mga nagrereklamo dyan dahil di nila mahanap yung rattling sound only to find out na yung screw lang is medyo loose na.
    easy fix though.
    Jun 2017
    #83
    easy fix though.
    Sorry..not familiar with tail pipe garnish... San banda po yun?sa ilalim po ba? Will i just follow the exhaust system? Tinanggal ko n ung muffler tip..kala ko dun galing pero hindi nawala yung kalansing/kuliglig sound.
    Apr 2014
    #84
    Quote Originally Posted by nealkenken View Post
    tama yung tinanggal mo na muffler tip. tail pipe garnish din tawag ko dun klasi.
    iscrew mo na lang nang maigi.
    Jun 2017
    #85
    Meron pa din po kase na kumakalansing kahit inalis ko na.. pag ibalik ko po ng maayus?matatanggal kaya po ang tunog?
    Apr 2014
    #86
    Kung di parin nawala, then that means di lang muffler tip ang may sanhi. Have someone drive your car sa garahe and troubleshoot nyo kung san nanggagaling.
    #87
    for muffler noise,
    have the car lifted up. then you can walk under it and make a real thorough examination.
    don't be afraid to use a (rubber) mallet.
    Jan 2018
    #88
    Question lng po anu recommend nyu mirage g4 or vios 1.3j ? I plan to buy po kz pero undecided prn bka magsisi kasi
    Sent from my A1601 using Tsikot Forums mobile app
    #89
    Quote Originally Posted by Dhex089 View Post
    buy the more expensive that you can still afford comfortably.
    i have not yet met someone who was un-happy because he opted to buy the more expensive car.
    Jul 2017
    #90
    i think you will not regret buying any of them
    Jan 2018
    #91
    Quote Originally Posted by KcireReaver View Post
    Thanks
    Sent from my A1601 using Tapatalk
    Feb 2014
    #92
    2014 Mirage GLS HB MT
    Ongoing issue ko ngayon ung biglang bibitaw ung rpm habang umaandar. walang rev kahit anong apak sa gas. kaylangan ko pang magfull stop. tapos nun magiging normal ulit. pero maya maya bibitaw na naman ung rpm. pinalinis ko na ung map sensor saka throttle body pero ganun padin
    may nabasa ako baka may pundidong ilaw lang or brake light pero okay naman lahat kahit fog lamps.
    40-50K na odo
    Jun 2015
    #93
    Quote Originally Posted by miggypet View Post
    Have you checked your brake lights kung pundido?
    have it checked via a scantool. makikita naman agad if there is really an issue.
    Feb 2014
    #95
    may nabasa din ako na baka fuse lang daw, chineck ko kahapon brake lights at hazard okay naman lahat
    Feb 2014
    #96
    sige tanong ko sa shell service center or goodyear kung meron nyan scantool. hassle ung issue nakakatakot tuloy mg long drive
    Apr 2014
    #97
    Pano mo chineck brake light? May tumatapak ba sa loob habang chinecheck mo yung brake light?
    Jul 2014
    #98
    Mahabang stick?
    Feb 2018
    #99
    40-50K na odo
    na experience na po yan ng tropa ko. pinalitan po nya yun Gas Pedal. meron daw kasi sensor yun naka kabit... most likely sira na po un sensor nyo. twice na sya nag palit. 5000+ php na po ata sa casa yun replacement. safety feature daw yun bigla mag Limp Mode para iwas accident...
    Apr 2014
    #100
    Quote Originally Posted by paranoiia View Post
    This is the first time i hear na may sensor ang mismong gas pedal.
    Pwede mo ba tanong sa barkada mo kung ano ang part number nung item na yon?
Mirage - Issues/Problems?
