Page 4 of 11 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 215
    so w/c is the better car, the mirage or the rebadged wigo?
    my brother and sister both have the mirage in their stable but i really haven't ridden in them yet, save for short trips w/in las pinas only - w/c is too short a ride to draw conclusions from
    Jan 2009
    #62
    The Swift is also my favorite minicar. But damn that backseat can barely fit a 2-legged human. Amputees will be fine though.
    That's somewhat true. But I am 6-ft tall and it's really not that bad. You just have to work with the front passengers so that they don't recline their backrest or slide the front seats all the way to the rear stops. :D
    #63
    my 2014 wigo is still absolutely problem-free at 40K km.
    not the engine.. not the body, chassis or underchassis.. at wala pa namang nabubunggo ang ulo sa loob sa kisame..
    it has gone thru slex.. thru edsa intermittent parking.. 3 hour traffic..
    Apr 2014
    #64
    Eto pa.
    Looks like all mirage gls (hb and g4, yung may navi at touch screen) HU's are affected by a time bug. Nagrereset yung time.
    Confirmed that 2015 gls HU's are not affected. Tested mine and it is all good.
    A recall might be in order. Or perhaps a software update.
    #65
    Quote Originally Posted by chronicle View Post
    Eto pa.
    there is a possibility, that for some reason, electricity going to the HU gets cut off, when starting the engine.
    the time and station settings can get erased.
    i do not know if the HU has a memory battery or not. if it has, it is probably dying.
    Apr 2014
    #66
    Only time is affected doc. Yung mga preset na stations is still in tact.
    Jan 2009
    #67
    For the sake of due diligence, check if you can have the clock sync to the GPS time (if it's a Navi model).
    On mine kasi (aftermarket 2DIN), the clock can be set three ways:
    1. Manually
    2. RDS Sync - Some relatively newer FM stations supports RDS to provide station ID and quite possibly other info like artist name, song name, etc. But I have yet to see stations provide time synchronization. But this was years ago.
    3. GPS Sync - As the name implies, it syncs time to the GPS everytime it gets enough satellites. The time can't get any more accurate than this
    Apr 2014
    #68
    Yung mga older models like 2014 and below doesnt have the option to sync it.
    Yung mga 2015 HU ang merong manual set or sync with gps.
    Jun 2015
    #69
    it does? Mine is 2015 GLS but doesn't seem to have the option to sync with gps. However, when using the navi, the time displayed on the map is from gps.
    Mukhang hindi lang maka move on to 2018 ang mga 2014 headunits. [emoji14] I read somewhere that it's the same for the Monteros?
    Apr 2014
    #70
    Yep. Meron. I checked mine earlier today.
    #71
    Yes ang dami sa montero thread....
    Sent from my SM-A720F using Tsikot Forums mobile app
    Apr 2014
    #72
    Nasa settings / navi / gps time (sync or ignore)
    Pag inignore mo, pwede mo na iset time sa under general settings.
    Jan 2018
    #73
    Pansin ko lang pag nag bumibirada ako ng todo kahit sa kaliwa o kanan para siyang nalulubak ano kaya problema nang mirage ko?
    When my dad was in the taxi business, our cars did more than 300kms per day...
    20k in 5 months is only around 150kms/day (26 days)
    hmmm, I've seen that "soft suspension" comment before...
    Regarding the "thin sheet of metal," have noticed (spec sheet) that the car is lighter that its counterparts... Is it really bad?[/QUOTE]
    #74
    Quote Originally Posted by Iphone6splus View Post
    [/QUOTE]
    "...para siyang nalulubak..."
    baka naman, tunay nga na nalulubak siya?
    what do you mean, sir?
    Jul 2017
    #75
    Quote Originally Posted by maxpedition View Post
    oo salhin mo sa casa ayusin nila yan under warranty yan wala ka problem kahit replace pa nila yan
    dinala na namin sa casa. mahina daw talaga buga ng compressor kaya papalitan daw total nakawaranty naman sya. pinabogahan lang muna tas ng add ng freon habang hinihintay ung replacement sparepart
    Quote Originally Posted by KcireReaver View Post
    added freon hmm. baka meron leak. whats the compressor brand? hope you get the ac sorted out before the summer season.
    Jul 2017
    #77
    hindi ko alam ung brand basta ung stock nya. bale ung last is the 2nd time na nakargahan ng freon. as for now malamig naman ung buga nya.
    Jun 2017
    #78
    Anyone encountered this?
    Pag magaacelerate ako glng full stop or glng menor, may naririnig ako n kmakalansing sa labas.. sa rinig namen e prang s likod n part s ilalim..
    D xa tmutunog pag nkaneutral lng or nkapark ts irerev lng.. 2017 glx cvt po..
    it could be a coin that fell into the trunk? or the spare tire is loose?
    Apr 2014
    #80
    Quote Originally Posted by nealkenken View Post
    Check you tail pipe. Might be the screw is loose.
Mirage - Issues/Problems?
