Results 1,841 to 1,850 of 2560
- Jan 2013
- 38
August 25th, 2013 01:59 AM #1841
- Aug 2013
- 6
September 1st, 2013 05:25 AM #1842
- Jan 2013
- 38
September 2nd, 2013 01:59 AM #1843Assume ko lang po na OK TPS nyo... May throttle plate adjustment po sa ibabaw ng throttle body. Counter-clockwise is to increase rpm (throttle-plate openning), Clockwise naman po is decreasing idle rpm (throttle-plate closing). Check mo rin MAF (Mass Air-Flow) sensor) --> disconnected: low idle with CHECK ENGINE light and engine will die. If MAF sensor disconnected and nothing changes --replace. Check rin air-filter with MAF sensor connected: remove air-filter and cover air-inlet going to the sensor --> there should be rpm changes. Minsan kasi kung marumi na air-filter, walang hangin nahihigop ang throttle-body lalo na nka on ang A/C. Kung konti ang hangin ang nahihigop ng sensor, hot air ang pumapasok sa throttle-body which causes staggering idle. Ang battery light sa dash kung low rpm means hirap mag-supply ng kuryente ang alternator mo due to low idle.
- May 2006
- 32
September 12th, 2013 03:51 AM #1844Hi Lancer Itlog owners. May questions lang ako about your cars' shocks. I was told na pwedeng replacement shocks for my VW Polo ang shocks ng Lancer itlog. Does anyone know kung may KYB replacement shocks for Lancer itlog? How about Zeon shocks for Lancer itlog? If meron, mga magkano po ang prices (front and rear shocks of either KYB or Zeon). Thanks!
- Jan 2013
- 38
September 13th, 2013 01:38 AM #1845
- Sep 2013
- 3
September 13th, 2013 08:59 PM #1846Magandang Gabi mga kaITLOG. HAving the same as problem as 1D4LV "kung di po naka aircon 1300-1500, pag switch ng aircon 700-900 po". Sana matulungan nyo po kami bago mabasag ang mga itlog namin. Dagdag ko na din po ang issue ng auto ko. Kapg sa highway mga 100kp/h kpg bumgal me yumayanig po ang manibela. Salamat sa tips and advice mga ka ITLOG. Kung may shop po kaung alam near Banawe sabhin nyo lang po.=)
Lancer 96
4G93 - Engine
4-2-1 headers
- Sep 2013
- 3
September 13th, 2013 09:07 PM #1847Mga Sir, pinagpalit ko po ung 2 gulong ko sa harap at likod. Tpos, sumasayad na po sa fender ung gulong kaht isa lang po sakay ko. Ngaun, pinacheck ko sa isang underchassis na service center, ang ginawa po nila, binaliktad ung spring sa likod and winelding. Okay po ba kaya un? Tawag daw po nila body lift daw po. Di po ba kaya back job un?
- Jul 2010
- 570
- Aug 2013
- 6
September 15th, 2013 01:12 PM #1849
- Sep 2013
- 3
Coolant...
