Originally Posted by
willyfernando
I went for the AEG. I specifically searched for a unit that can work on lower pressure, w/ a bigger mixing tank and a controllable heating system that is sensitive enough to cut-off when it gets too hot or the flow volume is too low. When I compared the inner parts of the other brands i found the AEG fitted more my criteria. By the way, my unit is an AEG BS 35---60E rated at 6KW *220V 60hz. It only needs a flow volume of 1.5 - 2.0 l/m and it's an instantaneous model. Right now it stays w/in the halfway to about 4KW setting and water stays hot all through out it's usage even on a summers day when water pressure is low. I hardly go beyond these settings and my electric bill ain't bad either. AEG gave me 3 years Warranty against product defect and service life. I just don't know w/ Panasonic and the others but normally mahaba naman warranty kapag H2O heaters.
